Speedometer gear question
Old Oct 24, 2013 | 02:40 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
The speedometer in My '87 F250 is running 3 to 5 mph fast. Has brand new P245/75R16 tires. (stock size is LT235/85R16) What gear would I need to get, to correct this? I have a C6 trans.
Old Oct 25, 2013 | 01:51 PM
78 & 87 Super Cab
Anyone????
Old Oct 25, 2013 | 04:02 PM
danr1's Avatar
danr1
Originally Posted by 78 & 87 Super Cab
Anyone????
Not enough to go on, would need to know the gear ratio and color/tooth count of gear in it now.
Example,
http://www.summitracing.com/parts/sd...FYxAMgod0zcAnQ
Just an example mind you, you'd need correct for model/trans/rear ratio etc to be sure to get the correct gear for your exact application. I just googled "ford speedo drive gear" that example came up.
Added C6 to that comes up, http://www.summitracing.com/parts/tci-881004/overview/
Old Oct 25, 2013 | 06:35 PM
78 & 87 Super Cab
Example,
I forgot the gear ratio info, sorry. I have 3.54 gears in it,
I have no idea what color/tooth count drive gear is in the trans.
Old Oct 25, 2013 | 06:46 PM
danr1's Avatar
danr1
Still not enough to go on, don't know what gear it has now how many teeth.
Take it out count them, order one that is the next size up, one that is little larger in diameter, has more teeth.
You state its 3 to 5 mph fast, so get one that is larger dia result in slowing the speedo down, the next size up from the one you have should do it only 3 to 5 off.
If it was reading the other way to slow for example, then you'd want to swap to a smaller dia drive gear, one with fewer teeth than the one you have in it now, that would speed the speedo up make it spin faster read higher.
Old Oct 25, 2013 | 07:17 PM
78 & 87 Super Cab
Yes, it is reading 3 to 5 mph fast. How is the speedo gear housing held in place in the trans on the C6?
Old Nov 19, 2013 | 07:44 AM
78 & 87 Super Cab
Did some looking underneath yesterday and the speedo cable is going into the GearVendors unit,Does that complicate things as far as replacing the speedo gear?
custom1106
Apr 16, 2018 12:49 AM
crucialprospect
16
Jan 3, 2018 05:04 PM
Shadowrider123
19
Jan 20, 2015 05:56 PM
vntgtrk
Oct 24, 2012 02:20 PM
BiltFordTuff
Jul 23, 2011 04:53 AM
