Getting SGII today any tips
Old Oct 24, 2013 | 05:53 AM
RKCORPS25's Avatar
RKCORPS25
I am finally getting a SGII and was hoping you guys could give me some tips. Will this show codes even if the CEL is not on. I am going to print off the temps and readings from the tech folder but is there anything else I should look at.
Old Oct 24, 2013 | 07:37 AM
93FordCTD's Avatar
93FordCTD
Is there anything wrong with Your truck? The SG does will scan and show You codes that do not trigger a CEL. In case You don't know, on their main website there is a list of some specific Xgauges for the 6.0L I'm still typing the codes on some of them, kind of tricky if You do it for the first time but easy to get the hang of it.
Old Oct 24, 2013 | 07:52 AM
Money-Pit's Avatar
Money-Pit
This should get ya started...
NECESSARY GAUGES TO ENTER HERE ------> https://www.ford-trucks.com/forums/1...e-ii-pids.html
VIDEO ON HOW TO ENTER GAUGES DOWN BELOW
Old Oct 24, 2013 | 08:54 AM
RKCORPS25's Avatar
RKCORPS25
I just looked at the scan gauge website is this all the xgauges. Also does the SGII come with anything per loaded. Thanks again I am about to go pick it up now.
Old Oct 24, 2013 | 09:04 AM
99ExpyProblems's Avatar
99ExpyProblems
Yes, it comes with some things pre-loaded, but most of the xgauges you need for the PSD are not included. You have to program them into the PIDs. I'll get a list.... hold on.
Old Oct 24, 2013 | 09:10 AM
Money-Pit's Avatar
Money-Pit
I must be typing invisible posts....or maybe I need to get stronger glue when I copy/paste.
Old Oct 24, 2013 | 09:33 AM
jswartz84's Avatar
jswartz84
Spend a couple hours programming and double checking.
Benny had some cylinder contribution codes a while back.
Old Oct 24, 2013 | 09:40 AM
99ExpyProblems
lol, Sorry man, I saw the link and I thought it was the youtube post... OP, following that link and it will give you the pids you need. It takes some time getting them entered.
Old Oct 24, 2013 | 11:24 AM
Keny1's Avatar
Keny1
new to Diesel Question for SG2
Hi All, I am buying a SG2, and reading the setup instructions, it ask to enter either Diesel A or Diesel B. I am buying a 04 6.0L. Which do I enter.
Thank You
Kenny Lyon
P.O. Box 643
Torrance, Ca. 90508-0643
(310) 631 3460
kenylyon@hotmail.com
http://www.facebook.com/keny.lyon
www.goldwingracingproject.info
http://GoldWingStreamliner.com/
Old Oct 24, 2013 | 02:15 PM
BLADE35's Avatar
BLADE35
Im diesel A
theres the procedure on the SGII site to determine But I think we are all diesel a
Old Oct 24, 2013 | 02:45 PM
Keny1's Avatar
Keny1
SGII
Thanks Blade35, I just went to Autozone and picked up my SGII, they gave me 10% off the price. Friday I will start to install and check out the truck I plan to buy, an 04, F250, 6.0L. The truck has the Service Engine Light on right now, and the good people on this site have all said, "Use SGII to check it out and keep it on the truck". This is my first Diesel and I may be in over my head. Anyone in the Compton Air Port area in South Los Angeles area that Could give me hands on help?? I can bring the truck to them, Or they can visit my Hanger at the airport.
Thank You
Kenny Lyon
P.O. Box 643
(310) 631 3460
Old Oct 24, 2013 | 02:48 PM
npccpartsman's Avatar
npccpartsman
Thank You
Kenny Lyon
P.O. Box 643
(310) 631 3460
SGII is a good diagnostic device but it won't read DTC's on an 04.
Old Oct 24, 2013 | 03:05 PM
Keny1's Avatar
Keny1
DTC codes
Hi npccpartsman, I thought the SGII would read the DTC! So, any suggestions on how I can get the "Codes" read?
Thank You
Kenny Lyon
P.O. Box 643
(310) 631 3460
Old Oct 24, 2013 | 03:12 PM
99ExpyProblems
Originally Posted by BLADE35
Im diesel A
06 here... Diesel a
Old Oct 24, 2013 | 03:54 PM
Keny1's Avatar
Keny1
Called Linear Logic SGII
Hi, I phoned Linear Logic to ask if SGII would read the DTC codes on an 04 F250 Diesel 6.0L. The lady at Linear said, " as long as it is the standard OBDII vehicle the SGII will read the code".
I hope she is correct for I have the Service engine light on!
Thank You
Kenny Lyon
P.O. Box 643
(310) 631 3460
