99 explorer brake problem
Old Oct 23, 2013 | 04:25 PM
gcar's Avatar
gcar
The brake pedal is hard to push at higher rpms when going from throttle to brake. It works fine at lower rpms. Also if you hold it at higher rpms it stays hard like vacuum booster quits working. Please help.
Old Oct 23, 2013 | 09:25 PM
shorod's Avatar
shorod
Maybe the check valve in series with the booster is faulty and allowing the booster vacuum to bleed off under high load/rpm.
-Rod
cwesner227
1983 - 2012 Ranger & B-Series
Sep 9, 2014 12:55 PM
Elk4me
Jun 15, 2014 10:07 PM
LTCPipkin
Aerostar
Oct 28, 2007 08:56 PM
philipwhite
Aug 16, 2006 08:06 PM
lotty1525
Sep 23, 2003 09:39 AM
