Radio Install Issues
Old Oct 23, 2013 | 11:38 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Just got my new double din radio in the dash. Got a fitment issue, so some more trimming is required.
Main problem is rear audio. I have no rear audio. I have a plug in the dash that I don't know what it does. I'm guessing now that is the rear audio. Is there an easy way to get it back? Another harness to use?
Thx
Old Oct 23, 2013 | 12:09 PM
kornfanjoe's Avatar
kornfanjoe
Yes you will need to trim he edges to fit any double din deck as this isn't truly double din. A dremel makes short work of it very easily.
As for the second plug, if I'm correct is a black and red square plug. This is for the DVD player, rear audio access point and such. Your rear most 3rd row speakers are on the main radio harness. I don't know if your aftermarket harness adapter connects to the third row because I never used it.
I have the doors run by an amplifier and the 3rd row by the deck.
Old Oct 23, 2013 | 01:43 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I have zero rear speakers at moment. No factory dvd. Just the 6 disc radio that was installed.
Old Oct 23, 2013 | 02:43 PM
ycis's Avatar
ycis
if you do a search, itll show you the wires you have to twist together in the center console to make the rear speakers work.
access is very easy (rear cupholder just pops right out) and youll see the bundle of wires going into the rear audio control unit.
I personally never got the 3rd row speakers to work in mine off the head unit...just the 4 door speakers...but I didnt mind as I plan on replacing the 3rd row speakers with subs to run off an amp already in the back anyway.
Old Oct 23, 2013 | 05:38 PM
Technologiq's Avatar
Technologiq
It may not be a loose/broken wiring issue. What head unit is it?
I need to find out whether Ford wired these in Parallel or series.
If they are wired in parallel then you're putting a 2ohm load on the head unit. Many aftermarket head units aren't 2ohm stable
If they are wired in series then you're giving them half the power the head unit would supply. If the head unit puts out 16w RMS, then it's half of that split between the 2 speakers (4w each).
Unless someone chimes in I'll have to wait until I pull my rear apart and use a multimeter to check the load. I have a feeling they are wired in series but I'm not 100%
Old Oct 23, 2013 | 06:21 PM
jh818's Avatar
jh818
Your rear speaker wires end at the plug that goes into the rear control panel in the center console. You jump 2 wires in the plug to reconnect from the head unit.
Old Oct 23, 2013 | 11:50 PM
ycis's Avatar
ycis
eh, if they (the front and 2nd row) were parallel...you would not have the ability to fade from front to rear (as they would be getting the same signal)
it wouldnt suprise me if the 2nd row and 3rd row were however...
Old Oct 24, 2013 | 08:12 AM
Technologiq
Yep - that's what I thought. The only thing that would surprise me though is Ford putting that 2ohm load on their head units which would cause heat and possibly shorten the life. Makes a little more sense that they'd do it in series and just half the power. When I pulled all the speakers out of my Ex they are all the same identical 4ohm 6x8 speaker.
The 'easiest' way for me to find out is to remove the panels again and measure how many ohms those rear speakers are working on. Those panels are a pain in the a** since you have to remove the seatbelts and trim to access (the worst is the driver side w/ the spare). It's important enough to me (and I think others) to find out what this is because you'll potentially fry head units if they wired them in parallel.
Old Oct 24, 2013 | 12:30 PM
ycis's Avatar
ycis
I have no sound at all coming out of my rears(3rd row)...so who knows...maybe they are already fried =)
Old Oct 24, 2013 | 10:48 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
a link or more info?
normally I can find what I'm after, but this is the first I've ever heard of doing this for a radio
so what would you recommend to avoid frying the HU? I can wire stuff, but I don't understand the reasoning behind why. I'm not after a booming system. Just one that works.
Old Oct 25, 2013 | 01:30 AM
jh818's Avatar
jh818
Try this link. Hope this helps.
https://www.ford-trucks.com/forums/1...l#post13036946
Old Oct 25, 2013 | 02:30 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
thx
turned out I didn't have to do anything special. I was fiddling with that connector in the console and my rear speakers started working. odd!
so yeah, didn't have to jumper anything. Just a loose connection or something. works great now. thx guys
glj
Oct 30, 2018 11:25 AM
Strummerpete
Mar 19, 2014 07:03 PM
2kflhr
21
Aug 22, 2009 12:21 PM
stevenn1
Nov 15, 2007 05:53 PM
MarlboroKlingon
Aerostar
17
May 9, 2005 12:19 PM
