Tips to get spider installed?
Old Oct 22, 2013 | 10:58 PM
Jesser02EX's Avatar
Jesser02EX
I've replaced my leaking I/C boots with ones from RR. These are stiffer, any tips to get the spider remounted?
Old Oct 23, 2013 | 12:49 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Nope. Just fight it. It'll go.
Old Oct 23, 2013 | 03:25 AM
SSSimon's Avatar
SSSimon
Don't do any of the boot clamps up, just back them right off to allow the IC boot to flex and move around as much as possible, then just work it in.
Old Oct 23, 2013 | 06:12 AM
Tugly's Avatar
Tugly
I used needle-nose pliers (no sharp edges) to guide the boot around the spider. It's difficult, but not as hard as other things I've done on the truck. I imagine myself pulling those off in 10 years when the boots have really sealed onto the spider. I think a box cutter will be in order.
Old Oct 23, 2013 | 07:19 AM
kawcrasher's Avatar
kawcrasher
No way YOU go ten years without pulling them off.
Old Oct 23, 2013 | 07:28 AM
SkySkiJason's Avatar
SkySkiJason
Thats funny right there! We are laughing WITH you Rich...
I put both boots and all 4 clamps on the plenums, then use a fat, round-shank screwdriver to coax the 2nd boot on the spider. The clamps RR sells are almost big enough... They are a PITA to get in the right place and tighten down. I keep forgetting to ask Clay about that..
Old Oct 23, 2013 | 08:43 AM
ScaldedDog's Avatar
ScaldedDog
I cut 1/4" off the boots to get the spider to fit. That's with an ATS housing, though, and those angle the spider really close to the plenum. The boots are still longer than they need to be.
Mark
Old Oct 23, 2013 | 08:52 AM
spongecop's Avatar
spongecop
Semper Fi
I used one of those hose tools. Screwriver looking thing with a twisted end. Just be careful not to nick one of your new boots.......ask me how I know.
Old Oct 23, 2013 | 11:28 AM
lartross's Avatar
lartross
It's really kind of a bit**. I carefully used a bladed screwdriver to gently move the boot onto the spider...
Old Oct 23, 2013 | 11:36 AM
Jesser02EX's Avatar
Jesser02EX
At least I'm not alone! For those that put the band clamps on after it was in place, do you have freakishly small hands? I'll fight it after work today, but last night I just called it quits.
Trey: boost leak detector question for you; I made the one in your video, I'm attaching it at the intake tube with the filter removed. I have the CCV set as stock. Am I missing anything? The turbo, I/C and plenums should all pressurize to 20psi. Just want to make sure. My previous leaks caused all sorts of issues.
Old Oct 23, 2013 | 12:34 PM
SkySkiJason
You'll be pressurizing crank case as well - no big deal... Pinch off ccv hose if you want to.
Old Oct 23, 2013 | 12:57 PM
Tugly's Avatar
Tugly
Originally Posted by Jesser02EX
...For those that put the band clamps on after it was in place...
Band clamps? You meant to say T-bolt clamps... right?
Old Oct 23, 2013 | 03:07 PM
Jesser02EX's Avatar
Jesser02EX
Yes T-bolt clamps.
Pocket
22
Nov 10, 2012 08:12 AM
urbex
May 11, 2012 01:40 PM
2005Dually
Feb 27, 2010 08:19 PM
Col Flashman
S. California Chapter
Dec 17, 2008 10:31 AM
empiretc
18
May 8, 2005 08:16 PM
