Binding during turning.
Old Oct 22, 2013 | 08:32 PM
icantdo55's Avatar
icantdo55
I know this has been discussed but I cant seem to find an answer to my particular problem.
99 expy 5.4 190K
Lent my truck to my brother and got it back with front end binding in turns, feels like 4x4 is on. I can shift it to 4x4 and l-low and shifts and works the same. I seen in my search to remove #104 fuse and I did that and there was no change still binding......now what do I try?
Old Oct 22, 2013 | 09:26 PM
alwaysfords41's Avatar
alwaysfords41
Do you have the limited slip rear? Some confuse that binding with 4wd binding.
Old Oct 22, 2013 | 10:22 PM
icantdo55's Avatar
icantdo55
I dont know. I know its never done this before. Horrible popping and clicking when turned and trying to move.
Old Oct 22, 2013 | 11:02 PM
SilverSS's Avatar
SilverSS
Did your brother use the 4wd or turn it on at all?
Old Oct 22, 2013 | 11:07 PM
icantdo55's Avatar
icantdo55
Like ever or recently?
Prob not used since last winter.
Old Oct 22, 2013 | 11:48 PM
icantdo55's Avatar
icantdo55
Is there a way to manually put it in 2wd? Obviously remove 104 fuse but how do I physically do it? Can I move what the motor should have?
The 104 has no effect on my binding.
I could pull driveshaft but is there an easier way?
Old Oct 22, 2013 | 11:53 PM
icantdo55's Avatar
icantdo55
Little more information. My truck went into this 4x4 locked mode when battery was changed today. Been stuck in 4x4 since new battery was installed.
That help anyone?
Old Oct 23, 2013 | 12:21 AM
alloro's Avatar
alloro
Have you tried disconnecting the battery just in case some of the on-board electronics didn't start up correctly?
Old Oct 23, 2013 | 12:39 AM
icantdo55's Avatar
icantdo55
Not yet. Did not pit 2+2 together till I was at work tonight. I'll try in the morning when I get home to the truck.
Old Oct 23, 2013 | 05:10 PM
icantdo55's Avatar
icantdo55
Removing battey did nothing so I guessing its a mechanical problem. Not wanting to remove the transfer case I chose to remove front DS. Wow should have done this years ago! Drives like a car not an oversized truck. Why did Ford not put a 2wd option on the dash. For 190K mikes its never been off road so I think I'm good.
Old Oct 23, 2013 | 07:28 PM
pdqford's Avatar
pdqford
They did. '97,98,03,04?
Old Oct 23, 2013 | 11:01 PM
icantdo55's Avatar
icantdo55
Guess I'm just unlucky.
Old Oct 24, 2013 | 05:52 AM
alwaysfords41
I think after 03 it has always been the four position switch.
Sandman68
Dec 25, 2018 06:42 PM
MRTQV10
Modular V10 (6.8l)
Jan 14, 2013 10:56 AM
robinwood
2004 - 2008 F150
Jul 26, 2004 12:15 PM
great white
Jan 28, 2004 07:17 PM
Mean Bone
2004 - 2008 F150
44
Jan 26, 2004 09:22 PM
