Won't keep running
Old Oct 22, 2013 | 06:29 AM
suburban_hotrod's Avatar
suburban_hotrod
Won't keep running
I bought a 1966 F 350 w/ inline 6cylinder at auction, was told it needed a new ignition switch. New switch installed and it starts but will not run over idle. Someone put a rebuilt carter carb on a fuel pump on and did a tune up, but like I said when I try to rev it up it stumbles and stalls out. The vacuum hose coming from the carb to the distributer has no vacuum. Looking forward to getting this old girl back on the road, was on the farm since new only has 18,768.1 miles .
Old Oct 22, 2013 | 06:55 AM
f5fordgirl's Avatar
f5fordgirl
First thing would be to check for a fuel filter, then make sure the pump was pumping ok, then remove the carb and go through it, float may be set too low.
Old Oct 22, 2013 | 01:02 PM
1tonner's Avatar
1tonner
May have the vacuum line to dist hooked up wrong. Is it to manifold vac?
adamdunn86
Jun 23, 2014 01:49 PM
darkpurp1e
31
Mar 31, 2012 08:12 AM
sammycooks
13
Mar 1, 2010 04:56 PM
rmoore7167
May 28, 2007 04:12 PM
Sport45
Aug 25, 2006 09:03 AM
