No Spark
Old Jun 25, 2002 | 01:09 PM
kioolt's Avatar
kioolt
No Spark
Old Jun 26, 2002 | 07:01 AM
Gates's Avatar
Gates
No Spark
Well here is the problem, on my 91 F150 302 4x4, four cylinders are not firing. I get a very weak spark if any on cylinders. The firing order is 15426378, cylinders 2637 are the ones that are not firing.
I know they are getting fuel, wet plugs, gas in oil (had to change oil yesterday). I measured voltage in the TFI harness and it is getting voltage, and if the TFI isn't working it wouldn't be getting fuel. I am thinking that it is the PIP sensor.
Any ideas or suggestions on what to check?
Thanks
Old Jun 26, 2002 | 07:24 AM
winfordr's Avatar
winfordr
No Spark
It sounds like you have at least one defective injector, and it is flooding those cylinders. You may also have an ignition problem, but if you have a cracked or stuck-open injector, you will ruin your engine if that is not corrected.
I am assuming you have already checked the distributor cap and plug wires for problems.
Winford
Old Jun 26, 2002 | 12:24 PM
Gates's Avatar
Gates
No Spark
I have installed new wires, plugs, cap and rotor.
How do I go about testing the injectors. I am going to get a new set of injectors from a friend next week so I might just switch them out.
I'll pull all the injectors off the motor tonight and inspect them. Thanks for your help
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
