Spring, Texas - Help
Old Oct 20, 2013 | 12:54 PM
Capt.Schenk's Avatar
Capt.Schenk
My truck started stuttering, then finally lost almost all power. It will still start, but it's not "drive-able". I was low on oil and was hoping that was the problem, but it wasn't. I had a spare CPS so I changed it on the side of the road just for the heck of it. Not sure if it means anything, but after adding oil, letting the truck sit for 48 hours, then starting it, I noticed air bubbles on the dip stick when I checked the level. My biggest problem is that I had to park the truck in front of my ex-wife's house. I want to get it diagnosed and fixed ASAP. Anyone in the area who can diagnose it?
Old Oct 20, 2013 | 01:22 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
This member is close to you and is good with these diesels:
Ford Truck Enthusiasts Forums - View Profile: Toreador_Diesel
Old Oct 20, 2013 | 01:30 PM
Capt.Schenk
Thanks. I tried to send him a PM, but not sure if it worked. I'm using the iPhone app rather than a computer. This is the first time I've tried this app.
Old Oct 20, 2013 | 04:01 PM
Stewart_H's Avatar
Stewart_H
I sent him a text message letting him know about this thread.
Stewart
Old Oct 20, 2013 | 04:04 PM
Capt.Schenk
Thank you. I'm messing with the truck right now. I have no idea where to start. Hoping it's an electrical issue.
Old Oct 20, 2013 | 04:08 PM
Stewart_H's Avatar
Stewart_H
Sounds like a bank went down, so I agree it definitely sound electrical, whether it's UVCH related or something else, it sounds like you're running on 4 cylinders.
Also, Tor just texted me back and said he's in a bad reception area, but he'll be glad to help.
Stewart
Old Oct 20, 2013 | 04:13 PM
Capt.Schenk
If he's able to, that would be great. Here's my cell if it helps: 281-865-8552
Old Oct 20, 2013 | 04:17 PM
Stewart_H's Avatar
Stewart_H
He's out and about right now, so I'm sure he'll post up when he gets back home in front of the computer.
Stewart
Old Oct 20, 2013 | 04:27 PM
Capt.Schenk
I found a couple of problems, but not sure if they're the cause of my main problem. A wire on the IPR harness is exposed, and both wires on the heater plug harness are exposed. I taped-up the heater plug wires and checked fuses 22 and 36. Left the heater plug disconnected, but this didn't solve the problem. The fuses were good. I also swapped relays 302 and 303 before I started the truck. I didn't repair the IPR wire yet. I plugged it back in before I started the engine. Not sure if it matters, but the IPR connector had a little bit of oil on it when I unplugged it.
Old Oct 20, 2013 | 04:30 PM
Capt.Schenk
I have a photo, but can't seem to figure out how to upload it.
Old Oct 20, 2013 | 04:52 PM
Capt.Schenk
Not sure if this is going to work. This isn't my photo. I found it on a post by Robin. It's pretty much what mine looks like. Could this be my entire problem?
Old Oct 20, 2013 | 05:10 PM
Bonanza35's Avatar
Bonanza35
I have know idea but it don't look good. Subcribing,
Old Oct 20, 2013 | 05:38 PM
Capt.Schenk
Just to clarify, that is not my photo, but my plug & wires are in a similar condition. Both my wires are still connected to the plug, but the insulation is gone and the back of the plug either corroded or melted.
Old Oct 20, 2013 | 06:12 PM
Mowing Man's Avatar
Mowing Man
If it was me, that would be my number 1 suspect if my truck wasn't running. Both the ICP and IPR are sensors that deal with HP oil, which is critical in the 7.3. I don't remember which one it was, but you can run with one of those sensors unplugged. I think it's the ICP, but don't quote me on that...
Old Oct 20, 2013 | 06:22 PM
jasonc76's Avatar
jasonc76
Truck will not run with Ipr disconnected. It will run with ICP disconnected.
