Spring, Texas - Help
Old Oct 20, 2013 | 06:40 PM
Capt.Schenk's Avatar
Capt.Schenk
Based on those last two posts, I guess this is my main question: will my truck start and run rough due to a short in the IPR wires?
Old Oct 20, 2013 | 06:45 PM
jasonc76's Avatar
jasonc76
My guess would be yes. That short is likely reducing the signal to the Ipr and the engine isn't getting the correct oil pressure to the injectors.
Old Oct 20, 2013 | 06:53 PM
Capt.Schenk
Anyone know of a quick and easy fix for this?
Old Oct 20, 2013 | 07:05 PM
F350-6's Avatar
F350-6
If you can't tspe the wires up, and you can't find a pigtail at the local parts store, cut the pigtail off the EBP sensor at the base of the turbo pedestal. And splice it into the IPR wiring. Check it first, but they should be the same connector. Leaving the turbo unplugged won't hurt anything .
Old Oct 20, 2013 | 08:50 PM
Mowing Man's Avatar
Mowing Man
^^^That is a great tip! I'll have to file that one away for 'Its 2 am with 6" of snow on the ground, my freaking truck just died while I'm out plowing snow, and how the heck will I lump this sucker back to the shop?' Thanks Chris! Reps!
Old Oct 20, 2013 | 09:01 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Called Captain Schenk, but got his voicemail...
I'd replace the IPR pigtail and go from there. I have another IPR, you can try if yours gives you a problem or is bad as a result.
Call me back tomorrow around lunch or shoot me a text and we can discuss further.
Old Oct 20, 2013 | 11:08 PM
mueckster's Avatar
mueckster
I've got a few injector harness plugs from an International 530E (same plug as IPR and EBP Solenoid) laying around. If you still need another plug, PM me with your address and I'll throw one in the mail to you.
Old Oct 21, 2013 | 05:21 AM
Capt.Schenk
Thanks for the replies and the phone call. My phone doesn't get a signal in my apartment, so I didn't get your voice mail until I left for work this morning.
I'm going to call the dealership this morning for a pigtail. If I can't find one, I'll cut off the connector from the turbo.
I'd still like to run a diagnostic test on my truck sometime just for the heck of it. I've had this truck for 10 months & 36,000 miles, and have had a few problems like this that keep popping up. This truck currently has 243k miles on it. I sold my last 7.3 with 400k miles, and never had these sorts of problems under the hood. I'm kind of wondering if Ford changed wiring manufacturers between 2000 and 2002.
Old Oct 21, 2013 | 06:17 AM
Toreador_Diesel
Dude, save a trip to the dealer, Roland will mail you the pigtail you need. I can run by your place sometime this week with the AE and we can see what else is going on with your truck.
Btw, head down to the Texas chapter forum, we're having tech day #3 November 1st and if you're able to make it and bring some parts, we can get your truck fixed up in one weekend.
Old Oct 21, 2013 | 07:06 AM
Capt.Schenk
Ok, I'll cut off the plug for the EBP and use it for the IPR. Hopefully that will solve my problem. I'm going to try to get out of work a little early today to make this repair. I'll let y'all know how it turns out.
I have to be out of town on November 1st, but I'd love to attend a tech day sometime soon. I'll definitely be on the look-out for the next one.
This week is starting to look a little hectic for me. If this repair doesn't work, I'll need a hand for sure. If the repair does work, I'll need to move on to the next emergency. Maybe we can find a day in the near future to run a test on my truck so that I can be embarrassed about (or blame the previous owner for) all the problems due to the lack of maintenance.
Old Oct 21, 2013 | 08:42 AM
Capt.Schenk
Maybe I'm seeing some bad info on google, but it looks like the EBP plug is the same as the ICP (3 wires), and different than the IPR (2 wires). Is this true, or am I seeing bad info?
Old Oct 21, 2013 | 09:46 AM
jasonc76's Avatar
jasonc76
Make sure you are looking at the right pig tail there are 2 that have similar names. The EBP sensor is mounted in the front of the engine between the HPOP reservoir and the fan.
The second pig tail controls the exhaust back pressure valve and is mounted in the turbo pedestal below the spider.
Old Oct 21, 2013 | 10:00 AM
  #28
Capt.Schenk
A previous post said to take the pigtail from the base of the turbo pedestal. Wouldn't this be the pigtail similar to the ICP with 3 wires?
I'll just get to the truck asap, and figure it out. It's hard to see from 30 miles away.
Old Oct 21, 2013 | 01:14 PM
  #29
BigAlsPSD's Avatar
BigAlsPSD
The sensor(EBPS) is located at the front of the motor above the water pump and will have the 3 prong. The plug for the solenoid at the base of the turbo for the valve(EBPV) is the 2 prong. Another thought would be to purchase an injector wiring harness and have 4 of those style plugs, many parts stores carry them.
Old Oct 21, 2013 | 05:17 PM
  #30
Capt.Schenk
Well, I cut the plug off of the EBP and spliced it to the IPR wiring harness, but that didn't solve the problem. I sure was hoping it was going to be that easy.
