Where can I find a adapter for my stock 1 barrel intake to be able to fit a 2 barrel? My one barrel has bit the dust (got a crack) and I was wanting a temporary fix until I'm able to put a 4 barrel intake with header
"This billet adaptor is used to install any Autolite, Holley, or MotorCraft 2V carb (up to 500 CFM) on a 240/300ci 1V intake manifold. The adaptor comes with a custom billet insert, which improves ar flow and horse power, and two stainless steel screws for mounting the adaptor to the intake (carb studs and spacers are optional). Gaskets not included. No machining required."
If your intermediate solution is to use a 2-barrel, you're going to have to re-engineer the throttle linkage, only to likely need to re-engineer it a second time to accommodate a 4-barrel. Considering your final plans, I'd just replace the 1-barrel for now and only go through the headache once.
