Fuel drain plug
Old Oct 19, 2013 | 02:29 PM
brandon.edwards's Avatar
brandon.edwards
Fuel drain plug
Where can I find the updated fuel filter drain plug? Anyone have a part number or where I can get it?
Old Oct 19, 2013 | 03:05 PM
acf6's Avatar
acf6
AutoNation Ford White Bear Lake Parts (previously Tousley Ford Parts)
Old Oct 19, 2013 | 03:21 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
What would the shipping be on that? Just wondering.
Old Oct 19, 2013 | 03:26 PM
acf6's Avatar
acf6
Not much likely. They just shipped my glow plug rail for 9 bucks via ups they sent my filter minder for like 5 via usps
Old Oct 20, 2013 | 12:52 PM
brandon.edwards
Thanks for the replies, I appreciate that. I got the updated plug, but now i face the problem of getting my old one out. It is rounded out and i just tried JB weld on it let it set over night, came out today and the weld wouldnt hold. So now im not sure what else to try. I dont want to replace the whole filter housing down there. Just dont have the means right now. Any other input is appreciated.
Old Oct 20, 2013 | 01:10 PM
69cj's Avatar
69cj
Drill a hole in it and use a screw extractor.
Old Oct 20, 2013 | 01:17 PM
brandon.edwards
Do you know how deep in that screw goes? I don't want to drill through anything important
Old Oct 20, 2013 | 01:23 PM
69cj's Avatar
69cj
Some people here have removed the cover and done it on the work bench. I've been lucky and the screw came out easily. It has a O ring, old and new, and they don't need to be torqued very tight.
Old Oct 20, 2013 | 05:21 PM
Mcrafty1's Avatar
Mcrafty1
I just bought mine there and that along with the Blue Spring upgrade kit with the cover was only $11.00 bucks to ship to Maine.
Old Oct 20, 2013 | 06:16 PM
Piolet's Avatar
Piolet
Ford dealer parts depts around my area have a little advertisement display for them at the counter. Never enquired about the price as I already have one .... but you could try there.
Old Oct 20, 2013 | 06:21 PM
brandon.edwards
Im not to sure in what you mean in removing the cover. Does the frame mounted filter housing have a cover that will remove?
Old Oct 20, 2013 | 06:32 PM
acf6's Avatar
acf6
not that i know of. but its not too hard to remove the fuel pump itself
Old Oct 20, 2013 | 07:26 PM
99ExpyProblems's Avatar
99ExpyProblems
You need the fuel line disconnect tool from Advance, AutoZone, Pep Boys or O'Reilly's to remove the fuel lines.
Manifold Cover / WIF Sensor Installation/Inspection Procedure.
<table border="0"><tbody><tr><td></td><td width="100">CAUTION:</td><td>SMOKING OR AN OPEN FLAME OF ANY TYPE IS PROHIBITED WHEN WORKING NEAR FUEL OR FUEL VAPOR.</td></tr></tbody></table>
  1. Disconnect both battery ground cables. Refer to Workshop Manual, Section 414-01.
  2. Raise and support the vehicle. Refer to Workshop Manual, Section 100-02.
  3. Open the fuel/water separator drain plug to release contents (Figure 1).
    Figure 1 - Article 06-6-5
  4. Disconnect the fuel pump, heater, water in fuel electrical connectors from HFCM (Figure 2).
    Figure 2 - Article 06-6-5
  5. Disconnect HFCM electrical harness from main vehicle harness.
  6. Disconnect the fuel hoses from HFCM.
    1. Remove the fuel hose retaining clips and discard. Disconnect the fuel hoses closest to the engine (Figure 3 number 1).
      Figure 3 - Article 06-6-5
    2. Press in the retaining clips and release the fuel hoses closest to the fuel <nobr style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id="itxt_nobr_25_0">tank</nobr><nobr style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id="itxt_nobr_25_0"></nobr> (Figure 3 number 2).
  7. Remove the screws and the old fuel manifold cover (Figure 4).
    Figure 4 - Article 06-6-5
  8. Inspect/clean debris from the HFCM water reservoir housing (max. 25 psi air).
  9. Install the new manifold and screws and torque to 44 lb-in (5 N-m) (Figure 5).
    Figure 5 - Article 06-6-5
  10. Install the new electrical harness and reconnect/reinstall fuel lines. Electrical harness will have connectors for the pump, for the water in fuel sensor, and one that connects to the main vehicle harness.
  11. Verify that there are no fuel leaks from the HFCM.
  12. Remove and discard heater 30 amp (J-case style) heater fuse.
    1. For 2003-2004 Model Years, remove 30 amp Fuse F2.105 located in Central Junction Box (CJB). Refer to 2003 or 2004 Ford F-Super Duty (F250/350) Wiring Diagrams (EVTM), Section 11 (pages 1-3).
    2. For 2005 Model Year, remove 30 amp Fuse F1.7 located in the engine Battery Junction Box (BJB). Refer to 2005 Ford F-Super Duty (F250/350) Wiring Diagrams, Section 11 (pages 4-5).
      <table border="0"><tbody><tr><td width="80">NOTE:</td><td>DO NOT REINSTALL HEATER FUSE (FUSE IS NOT REQUIRED WITH NEW HFCM MANIFOLD).</td></tr></tbody></table>
<table border="1" cellpadding="3" cellspacing="0"><tbody><tr><th align="center">PART NUMBER</th><th align="center">PART NAME</th></tr><tr><td class="NOBOTTOMBORDER" align="left">6C3Z-9B249-B</td><td class="NOBOTTOMBORDER" align="left">HFCM Kit</td></tr></tbody></table>
Old Oct 20, 2013 | 07:31 PM
69cj's Avatar
69cj
Sorry if I mislead you, I think expy has u covered.
Old Oct 20, 2013 | 07:34 PM
99ExpyProblems
I forgot to add, that obviously you can't open the drain screw, that's why you're removing the cover right? lol
so it's going to blow fuel everywhere when you get those fuel lines off. Wear goggles and don't have your mouth open... You've been warned!
