Oil dip stick
Old Oct 19, 2013 | 05:49 AM
tomrflorida's Avatar
tomrflorida
Oil dip stick
I am putting a 5.0 out of a 89 Bronco ( bought at a swap meet just for the core & bolt on pieces so it may be from anything) into my 49 Ford F-1 I used the oil pan & timing cover that came with the engine. I bought a rebuild ATK engine and changed the bolt on parts and stuck the engine in the truck NOW i started to think about the oil dip stick and can not even find where it used to go so I can start to find a replacement. The oil pan has the sump more towards the back, put not all the way back. I needed this style pan because I used a Mustang 11 rack for steering. Any ideas where to look ?
Old Oct 19, 2013 | 02:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by tomrflorida
I am putting a 5.0 out of a 89 Bronco ( bought at a swap meet just for the core & bolt on pieces so it may be from anything) into my 49 Ford F-1 I used the oil pan & timing cover that came with the engine. I bought a rebuild ATK engine and changed the bolt on parts and stuck the engine in the truck NOW i started to think about the oil dip stick and can not even find where it used to go so I can start to find a replacement. The oil pan has the sump more towards the back, put not all the way back. I needed this style pan because I used a Mustang II rack for steering. Any ideas where to look ?
Why did you type this question in the 1948/56 & 1967/72 forums instead of the 1987/96 forum that would have been apropos?
No parts catalog pic available, as FoMoCo only shows one pic...for all 1980/96 V8's, so it worthless for identifying the location of the specific years/applications for this 5.0L's dipstick/tube.
Look under the hood of one of the following to find the location.
F4TZ-6750-D (replaced E9TZ-6750-E) .. Engine Oil Dipstick.
1989/96 F150/250 & Bronco 5.0L
F2TZ-6754-A (replaced E7TZ-6754-B) .. Engine Oil Dipstick Tube.
1987/96 F150/250 & Bronco 5.0L
Old Oct 19, 2013 | 03:38 PM
JEFFFAFA's Avatar
JEFFFAFA
F2TZ6754A is about 2 feet long and presses in a hole. There is no screw in fitting on the bottom of it. On small block Fords I have seen dipstick tubes mounted in the passenger's side of the timing cover down close to the oil pan. 2 feet is too long for this position however. I have also seen them going straight in to the block close to the oil pan.
Old Oct 19, 2013 | 07:40 PM
NumberDummy
1990/96 applications, F4TZ-6750-D replaced E9TZ-6750-E taken from 1990/2001 light truck parts catalog on microfiche.
lovethosefords
Apr 16, 2018 10:43 AM
brian.b
Jan 11, 2016 02:54 PM
tomrflorida
1978 - 1996 Big Bronco
Oct 22, 2013 08:22 PM
brkellogg
Jun 8, 2013 02:01 PM
Basswood
Oct 1, 2012 07:40 AM
