6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Cab Fumes
Old Oct 18, 2013 | 10:38 PM
MxDad567's Avatar
MxDad567
Cab Fumes
When driving my 08 F350 dually at low or stopped speeds I get a strong odor of diesel fumes in the cab. It is not 100% of the time but lately a lot more often. It is almost to the point I will not be able to drive it. Seems more when heater/Ac is on
Any ideas? Up pipe was checked a few years back.
Old Oct 19, 2013 | 06:11 AM
golfmedik's Avatar
golfmedik
A misaligned up pipe or the gasket between the turbos are usually the problem. These pipes find away of getting misaligned themselves somehow. On my work 6.4, twice it was the gasket and once was the pipe. It was the tech's fault on the pipe though.
Old Oct 19, 2013 | 11:12 AM
cuda66's Avatar
cuda66
Mine is like that when it regens, maybe that is what's going on with yours?
Old Oct 19, 2013 | 12:09 PM
MxDad567's Avatar
MxDad567
Regen is worse. Seems like comes through vents. I will say of all my diesel trucks I own this one is the stinkiest. My cat and Detroit truck engines done smell near as bad as this truck does
Old Oct 20, 2013 | 07:29 AM
SANDDEMON08's Avatar
SANDDEMON08
Yep my same thoughts i have a dpf delete and never smell a thing unless the windows are down, i had the up pipe issue associated with fumes in the cab, adjusted it problem gone worst cause you could have a cracked up pipe but you might tend to hear that underload.
Old Oct 21, 2013 | 05:29 PM
fredetteb's Avatar
fredetteb
Same thing happened to me earlier this year. Ended up being the Y pipe. Luckily it is considered part of the EPA required emissions system and was covered under warranty. Bad news it is a cab-off repair and took about a week.
Old Oct 22, 2013 | 09:37 PM
MxDad567's Avatar
MxDad567
My warranty is out so I am basically screwed if the Y pipe is bad. 2 years ago I complained of the problem and they lifted cab and replaced a few things. Never really stopped the problem 100%. I had it out again tonifght and as long as I am driving pretty fast its ok. If I just on brakes to stop the fumes engulf the truck.
Franko72
60
Apr 13, 2013 12:02 AM
97biostroke
Nov 27, 2012 10:44 PM
bad306fox
22
Feb 15, 2012 09:46 PM
StanleyZ
Jun 23, 2011 08:04 AM
2006powerstroke90
Jan 14, 2011 09:34 PM
