Cleaning Throttle Body
Originally Posted by bassaway
The link earlier in this topic explaining how to clean the throttle body does not work anymore. Could someone briefly explain what to do when cleaning the throttle body? Thanks!
Here's the long version:
https://www.ford-trucks.com/forums/s...d.php?t=254443
Originally Posted by Rockledge
Wow, that is a bummer.....you are now the second person that I have heard that happening to. Someone over at the Taurus Car Club of America did the same thing.
i
well personally i wouldn't worry with it.
it's in a high heat enviroment so it will melt.
after that it will get pulled into the chambers and burned. should it cool on the valve seat fine it'll just heat up and mealt again. something of that nature i would tend to let it go. could cost ya alott more than it's worth to get it out. chances are you already got rid of it anyhow.you can use that tube though.
all you have to do is put in the nozzle then a dab of super glue on it and it's there to stay (most of the time).
the tb cleaner that ill be using for this on my truck is designed not to eat that teflon away so im good there lol. plus i can get about all i want (half empty cans at work) for free. it's already paid for by customers but alott of times you don't need the whole can lol so we save em.
well finally got around to cleaning the tb on my baby (finally) today got the tb the maf the idle air control valve and the air intake temp sens loose and cleaned em all out. it looked like mud running out of em when i was spraying em down lol. got them down to a new shine. put her all back to gether hooked up the bat and hmmmmm i had it flooded with tb cleaner. lol it took me about 6 mins to get her fired up and once i did i run the dog **** out of her. i couldn't belive the stuff coming out of my pipes either. the thing has got so much more power now idles smooth and the frickin pinging is gone. a job wwell worth doing and can easily be done well inside 30 mins.
Throttle Body
Originally Posted by saintthomas
I cleaned my throttle body last weekend. Man there was more carbon there than on the bottom of a burnt bisquit! I have 76K on my Ranger. The person that had it before me took great care of the outside but not the enginge. I am sure they never cleaned it. I used CRC and they recommend you clean it every 3000 miles! Now I don't know about that often but afterseeing what was in there I promise to clean it often. By the way, it didn't help the ping any. However, there is a noticable improvment in throttle response.
I have a 1997 Ford Ranger and I am in Iraq at this time but I will be leaving here and going back to Korea where I am stationed, with the U.S. Army at Camp Casey. My ford makes a lot of noise from the air inlet / Throttle Body when the engine worms up to worm or higher but the engine never over heats, just makes a lot of noise, I don’t like to drive it because of all the noise, it sounds like a jet engine. Can anyone help me with a solution?
Leland Butler
AMC/LSE
FOB Warrior
Kirkuk Iraq
Leland Butler
AMC/LSE
FOB Warrior
Kirkuk Iraq
Welcome, and thanks for serving Lee!
It sounds like you might have one of those noisy IAC valves.
https://www.ford-trucks.com/forums/s...hreadid=136188
Throttle Body
Hey all, I couldn't help but notice all the talk about throttle bodies. I know that with the 4.0 it makes a huge difference to upgrade throttle bodies (like BBK 66mm). Is there an upgrade for the 3.0 ranger around? Does anyone know.
Also, I know that some vehicles like S-10's are interchangable with bigger OEM throttle bodies from different vehicles, like pontiacs; for that aftermarket gain at a fraction of the pricce.
Does anyone know if say a 3.0 taurus or windstar throttle body is a) a bigger throttle body and b) will bolt up to the 2000 ranger 3.o v6? Or if there are any aftermarket throttle bodies made for the vehicle? Maybe also, will a 4.0 stock throttle body fit?
I have a cold air intake, but I just want a little more from the intake. Any recommendations are welcome. And on a technical note, what is the bore (mm) of the OEM throttle body in the 3.0?
THanks a lot for any input.
Originally Posted by Sandmann56
Does anyone know if say a 3.0 taurus or windstar throttle body is a) a bigger throttle body and b) will bolt up to the 2000 ranger 3.o v6? Or if there are any aftermarket throttle bodies made for the vehicle? .
I just recently ran some "Sea-Foam" cleaner through my 2004 3.0 w/ 33,000 on it. I also cleaned the Idle Control Valve, MAF, and TB while I was at it. The TB was filthy as well as the ICV. This cleaning went well and solved my idle dip which would stutter lower than 800 rpms making it seem as if my engine was going to kill. My engine doesn't have significant HP gains like some people would like to see but I definitely have a sharper revving engine with a much more smoother, and consistant idle.
Negligible benefits to claning the throttle body????? I can tell you it is very beneficial. There are several reeasons why Ford would not suggest it. One is the liability aspect. Some moron sprays half a bottle of TB cleaner in the intake and washes all the oil off cylinder walls then sues Ford. Any major company also has to take care of its dealers and garages. If Ford wanted to they could make vehicles that had virtually no maintenance. BUt why would they? The majority of car owners are not going to home repair things anyway. And then all those high priced income making entended warranties would be garbage. Ford makes great vehicles but it is still a profit oriented company. And that is the bottom line.
Last edited by FORDMANGT40; Sep 12, 2014 at 05:35 PM. Reason: Just adding to my advice.
Budman1962
2009 - 2014 F150
Jun 20, 2016 09:23 AM
RUSTY_BUT_TRUSTY
Aug 4, 2015 06:26 PM
What was I thinking
Apr 19, 2014 07:27 AM
Exp4Life
Oct 17, 2001 05:25 PM
