hard to shift
Old Oct 17, 2013 | 05:19 PM
86 FORD GUY's Avatar
86 FORD GUY
hard to shift
2000 ranger 3.0 auto 4wd hard to shift. are the cables known to stretch?
Old Oct 17, 2013 | 08:56 PM
CBB9M's Avatar
CBB9M
What cables? There are none that are part of the shifter or the clutch.
Old Oct 18, 2013 | 05:33 AM
Frozen_Joker's Avatar
Frozen_Joker
By hard to shift, are you stating that it shifts rough? Or does it not shift till a high RPM? You'll have to be more specific on the issue at hand. Thanks.
Old Oct 18, 2013 | 06:49 AM
86 FORD GUY
no the shift lever on the colum is very stiff and hard to move also it seems that it is a little off when lined up with th prndl
Old Oct 23, 2013 | 02:33 AM
Frozen_Joker
Sounds the linkage is messed up. As for it being off, it's a common ford issue and my older ones have always done it. I never bothered to fix it. But its all to do with the linkage going from the shifter to the trans. That is the best place to start!
Old Oct 23, 2013 | 07:20 AM
wtroger's Avatar
wtroger
First ensure the torx bolts holding the shift lever to steering colume are tight. There has been issue with transmission control switch on the side of the tranny causing this issue. And lastly the shift cable can get bound up.
Old Oct 25, 2013 | 07:27 AM
86 FORD GUY
Thanx I will take a closer look this weekend
Ron Crawford
1978 - 1996 Big Bronco
Dec 16, 2003 11:30 AM
