7.3 surging
Old Oct 17, 2013 | 02:06 PM
totavikid's Avatar
totavikid
7.3 surging
I have a 02 7.3 that has a surging problem at all speeds but seems to go away once I engage the cruise control. Any ideas?
Old Oct 17, 2013 | 03:02 PM
thomabb's Avatar
thomabb
Have your throttle position sensor checked.
Old Oct 17, 2013 | 05:21 PM
totavikid's Avatar
totavikid
7.3 surging
what is required to check the throttle position sensor?
Old Oct 18, 2013 | 07:41 AM
thomabb's Avatar
thomabb
Where are you? Someone on this board with a scanner that can log live data may be near you and willing to check it.
Old Oct 18, 2013 | 08:03 AM
thomabb's Avatar
thomabb
If you have a multimeter, you can probe the voltage output - key on engine off - I think it is like 0.4 volts at idle and 4.5 volts at the floor. The key to your issue is the voltage should not vary if the pedal position isn't changing.
Old Oct 28, 2013 | 09:35 AM
totavikid's Avatar
totavikid
Can the sensor be replaced without replacing the whole pedal assembly and where can i get one? Dealer wants upwards of 200 for a pedal. Sad thing is I just replaced the pedal a couple of years ago
Old Oct 28, 2013 | 11:34 AM
HKusp's Avatar
HKusp
It depends on what year your truck is (I think) whether you can change just the TPS or have to do the whole pedal assembly. I am not sure what years have the whole assembly and which you can change the TPS separate. But, you can try cleaning it with electrical contact cleaner first. A lot of times it takes care of minor issues like you are describing, if that is what the problem is to begin with. I would try that before replacing anything, it's obviously much cheaper.
Old Oct 29, 2013 | 07:39 AM
thomabb's Avatar
thomabb
Don't throw parts at it. Make sure the sensor is your problem first.
Unfortunately, some years of these trucks came with the TPS integrated into the pedal assembly. BUT, I think if you shop around you will find $200 is a little steep.
neuscda
May 13, 2015 07:23 AM
Reed Russell
May 8, 2015 05:32 PM
yonu
North Carolina Chapter
Apr 10, 2015 09:00 AM
mrboo
17
Oct 8, 2004 10:40 AM
