On my new to me '03 Excursion (I've owned it for 1.5 weeks now), I'm starting to get through the 1st level of issues (Wandering - fixed, Speedo/ABS issue - still working on that, changing the rear diff fluid this week, hopefully).
Now, I want to look into why the manually locking hubs won't turn. When I brought it up to the Previous Owner, who was about as mechanically inclined as my Golden Retreiver, he said "these are auto locking hubs. I never turned those things before".
They are frozen in the non-locked position, so I have to pray that I never need to actually manually lock them.
Has anyone ever had any luck at un-freezing stuck hubs? I've started the liberal application of PB Blaster process.
You can check the Tech forum above and I just had a good thread chat a few days ago.
they are really simple to take apart. There is a snap ring holding the outer hub housing on. If it is really stuck in there tap on it with a rubber mallet or dead blow hammer ..(or thick rags and conventional hammer) but once that snap ring is out it should just pull out. After that there are more snap rings...
get all the hub and components out, clean, and re-pack with grease.
If you never took one apart just place the parts in an order as they come out to re-install at a later date. There are also tons of videos on this subject.
Good luck
If you feel the locking hub can not be salvaged there are few aftermarket and better products for a hub replacement. It might be a good idea to purchase some anyways since you will have it apart. Both Warn and Superwinch replacement hubs are good. Maybe some supporting vendor can come by on your post and sell you some.
That's a good point on the ease of getting them off...don't even need to take the tires off!
The internals of your switch are seizing, just like you said (posted) so how are you confused?
Did you already try the ATF trick in the tech folder?
Stewart
So I've removed all the guts of the locking hub itself. Are you saying the internals of the actual **** switch are seizing and if I can't turn it, is atf fluid really going to help it break lose?
Secondly, is there a way to purchase just the housing/switch **** itself it seems most if the internal components are still in great shape, but the **** is super stiff.
Thanks,
Brett
Stewart. Thanks for directing me back to what I had read 3 times prior (but had recently forgotten since I was so hopeful the sticking was going to be caused from the internals of the hub itself).
I just re-read all the info about getting the hub switch back to functioning.
As a follow up to my last question though... is there a place you can buy just the external housing (with ****). It looks like I may be too far gone. I'm going to try to soak it and work it, but if it's too bad, can you buy just the housing from someone and use my internals from my current manual locking hub to save some money?
This doesn't address your question directly, but after replacing the OEM hubs twice in the last two years I gave up on the OEM type and installed manual. A pair of Mile Markers cost less the one OEM.
Ah, I thought you were talking about the internals of the sealed actuator.
Most opt to replace with Warn or Mile Marker actuator switches.
Stewart
Stew...
Thanks for your replies. What are the differences in the way the OEM ones that you provided a link to in eBay versus the Warn or Mile Marker ones function? I lose the Shift On The Fly feature, right? Or do they function the same way (manually turn to lock hubs before possibly using ESOF to engage if necessary)?
Secondly... all those auctions in eBay you listed are for full units, right? What I was curious about was purchasing strictly the housing (aka turn ****) without the internals. All my internals (cogs / gears / washers / springs) are in great shape. I just need a new turn **** and housing ... if that makes any sense. Or do you have to purchase the entire assembly as a whole?
You have to purchase the whole thing. They are not cheap. You do lose shift on the fly with the manual hubs, but you have assurance that they are either locked or in my case unlocked. Mine were staying engaged and spinning the front end while driving. I pulled them apart and cleaned/greased them several times, but they would still hang engaged after using 4x4. Probably due to a weak disengage pulse from an aging vac seal in the hub.
