neutral safety switch
Old Oct 14, 2013 | 11:02 AM
adam10's Avatar
adam10
ok I drove my truck yesterday and it was fine. went out today and it wouldn't start at all.batteries good and I was getting voltage to the relay thru the small wire(like 3 volts).jumped solenoid from battery and it turned over so I pulled the pigtail of the nss and one of the pins is completely corroded off.i am assuming this is my no start condition?
Old Oct 14, 2013 | 12:16 PM
BillyBob69's Avatar
BillyBob69
Probably is. If the ignition isn't getting the signal that you are in park or neutral, it wont allow power to the starter.
Old Oct 14, 2013 | 02:23 PM
adam10's Avatar
adam10
went and picked one up.auto zone only place that had it in stock.took longer to pull the broken pin out of harness.they were all corroded bad.
Old Oct 14, 2013 | 02:29 PM
BillyBob69's Avatar
BillyBob69
Make sure you put some dielectric grease on there to keep it from happening again. That piece gets a lot of road grime and moisture abuse where it is located.
Old Oct 14, 2013 | 02:31 PM
adam10's Avatar
adam10
thanks for the tip.did that already though
zhicks16
38
Dec 18, 2018 10:58 PM
Mn246
Jan 31, 2018 10:54 AM
ameizl
1983 - 2012 Ranger & B-Series
Nov 21, 2014 11:12 AM
neetso
Electrical Systems/Wiring
May 15, 2004 08:33 AM
Hottarod
Nov 8, 2001 06:36 AM
