Expedition Air Conditioner?????
Old Jun 19, 2003 | 07:19 PM
njxlt's Avatar
njxlt
I have a 98 Expedition and last week dumped a 14oz. can of 134a freon in the system. I used one of those color coded dummy gauges from Strauss Auto with the colors on it, and it said it was borderline low (about 25psi) so I put a can in and it went up to about 30 psi now it seems just driving around with the setting to cold and on floor&panel (not air or max air) that I have a whole lot of water dripping from the truck that I definitley didn't notice before. Is it possible the air is running even with the dash setting not on air???? Any clues or suggestions???Or is this normal???
Old Jun 19, 2003 | 08:50 PM
user 8429720834's Avatar
user 8429720834
Banned
With the engine running check the A/C compressor to see if it is turning with your floor&panel setting and then check it through each setting to identify when/if the compressor is running. If it turns in all setting the A/C compressor clutch may be stuck or defective.
Old Jun 19, 2003 | 08:51 PM
1956MarkII's Avatar
1956MarkII
Unless you have a separate push-button to engage the A/C compressor (like Windstar or current-model Explorer), then ALL Ford A/C units will run in every setting except "floor" and "vent" (or "panel"). Any other setting (floor/ panel, floor/ def, def, a/c, max a/c) and your A/C compressor is engaged.
Old Jun 20, 2003 | 10:38 AM
njxlt's Avatar
njxlt
well than i'm not so worried about compressor trouble since it seems to be only when you say it should, thanks again, this forum has an abundance of knowledge!!!!
spoke69
Jun 2, 2012 09:55 AM
knightridder45
May 6, 2011 11:08 AM
TNT in Round Rock
Jan 6, 2007 10:15 PM
cedman
General Diesel Discussion
18
Dec 13, 2006 04:59 PM
Chevy Sucks
Feb 17, 2006 09:13 PM
