84 F250 Electrical Problem
Old Oct 13, 2013 | 09:09 PM
Old Time Ford's Avatar
Old Time Ford
I have an 84 f250 5.8 that has an electrical problem.When the truck is left running it will go dead about the time it gets to normal operating temp.The problem I have found is the voltage regulator.When I take it off the fender the problem went away so I did some testing with a test light and found that the metal part of it has positive current . When I disconnect the voltage light wire it stops( there is no current on the outer metal of the regulator). I have tried changing the regulator. Need some ideas to what is causing this problem.It does have a light and not a gauge.
Old Oct 13, 2013 | 09:17 PM
Gary Lewis's Avatar
Gary Lewis
The regulator is supposed to ground against the fender. If you have it off it cannot ground so can't do it's job.
Old Oct 13, 2013 | 09:23 PM
Old Time Ford
When it is mounted to the fender the truck will go dead.
Old Oct 13, 2013 | 09:30 PM
Gary Lewis's Avatar
Gary Lewis
Then either the regulator is bad or the alternator, or both. In my experience it is good to replace them in pairs as I've seen one take the other out. You can take the alternator in for testing, and may be able to test the regulator as well.
Old Oct 13, 2013 | 10:21 PM
Stangrcr1's Avatar
Stangrcr1
Or even better to go to the 3G alternator and no regulator...
mchandford71360
18
Jan 8, 2019 09:13 AM
valley1221
Apr 25, 2013 09:21 PM
caf250
Electrical Systems/Wiring
Dec 14, 2008 01:53 PM
ken's 80
Sep 2, 2008 05:51 PM
pracklam
Jul 31, 2000 05:34 PM
