Warn hubs and center cap gap
Old Oct 13, 2013 | 11:43 AM
FallstonYJ's Avatar
FallstonYJ
First off, sorry if this has been answered before but after extensive search all I could find were a couple of old threads with expired pics/links.
After much deliberation I decided to go to the Warn hubs for my 2003 Excursion. I didn't know ahead of time that they were much shorter than the OE hubs which consequently leaves a gap at the center cap. Obvious question is how to solve this problem. I read a couple of suggestions that there are caps from other years that would fit but I cannot find exactly which caps would work. Also saw mention of modifying my original caps but couldn't find a clear method for doing this.
Any suggestions, valid links etc. would be appreciated!
Thanks for your time, Tom
Old Oct 13, 2013 | 12:50 PM
Stewart_H's Avatar
Stewart_H
Yes, there's a way to mod the hub cap cover to shorten it. I have it saved somewhere...lemme see if I can find it.
Stewart
Old Oct 17, 2013 | 10:08 AM
FallstonYJ's Avatar
FallstonYJ
Stewart
Hey Stewart......any luck?
Anyone else have any ideas?
Thanks!
Tom
Old Oct 17, 2013 | 10:42 AM
hav24wheel's Avatar
hav24wheel
I really didnt find the gap big enough to worry about.....
Old Oct 17, 2013 | 10:49 AM
FallstonYJ's Avatar
FallstonYJ
Mine looks a lot worse than that!
Old Oct 17, 2013 | 12:03 PM
BEARDOWN's Avatar
BEARDOWN
edit.. wrong link
Old Oct 17, 2013 | 02:20 PM
Stewart_H's Avatar
Stewart_H
Thanks!
Tom
Crap, sorry Tom, I got distracted and then my ADD kicked in and I forgot about this thread.
I'm finishing up some stuff right now and will look for it later today and post back tonight.
Stewart
Old Oct 17, 2013 | 07:16 PM
sammie0126's Avatar
sammie0126
Strange....mine are as snug as a bug in a rug. Were there different depths on the center caps between the years?
Old Oct 17, 2013 | 07:27 PM
EXv10's Avatar
EXv10
But do you use stock caps on your non-stock wheels? That picture is dark.
Bug in a rug, that brings me back
Old Oct 17, 2013 | 07:56 PM
Magilla_v6.0's Avatar
Magilla_v6.0
She has steel rims on, they are thinner than the aluminum ones. That's why there is a difference.
Old Oct 17, 2013 | 11:12 PM
Stewart_H's Avatar
Stewart_H
Thanks!
Tom
Ok, I thought I had saved the instructions and accompanying pictures, but I can't find it anywhere, so after searching extensively, I found a thread where the mod was talked about.
Originally Posted by Antelope V-10
Here is one way. I have not tried it though.
4WD lug nut fix pictures from cars photos on webshots
Just finished the center cap mod, pretty straight forward process if you follow the photos and directions.
I found a set of 99 F150 caps from the directions on Ebay Sunday and they came today. I went to a couple of salvage yards on Saturday without any results so I bid them and won.
The Mile Marker Hubs sit in a little further than the Warns in the directions. I found that one side was slightly different than the other.
When you cut the tube that holds the nut clips make sure the clips stick out enough if the first one you put in doesn't trim it down a little more, it's easier to remove 1 as opposed to 4 (did it 2 times with all 4)<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype class=inlineimg id=_x0000_t75 title="Stick Out Tongue" stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" alt="" src="http://images.ford-trucks.com/forums/images/smilies/tongue.gif" border="0" o</v:shapetype>
I also used a deep socket to install the new clips in so they seated real nice into the bottom.
Unfortunately, the website documenting the mod, with great instructions and lots of pics, is now a dead link.
Stewart
Old Oct 17, 2013 | 11:19 PM
Stewart_H's Avatar
Stewart_H
Christina, what Magilla posted....
From another thread:
Originally Posted by Ponyboychris
If you have the stock steel chrome wheels, then the ring fits right to the Warn Hub. If you have the stock aluminum wheels, there is a gap - from what I've heard.
This is what the hubs look like with the steel rims on my '02.
Stewart
Old Oct 17, 2013 | 11:34 PM
EXv10's Avatar
EXv10
And this post;
https://www.ford-trucks.com/forums/1...ml#post9899952
Old Oct 18, 2013 | 05:44 PM
sammie0126's Avatar
sammie0126
Ahh ok that make sense. I did swap to the steel rims a few month ago....but that's another story.
Old Oct 20, 2013 | 12:15 AM
04fivefour's Avatar
04fivefour
Mine had a huge gap with the factory 04 wheels. with the 08's it sits perfectly
