MAP Sensor
Old Jun 14, 2002 | 07:44 PM
panamint's Avatar
panamint
MAP Sensor
I have a 92 F-150 with a 5.0 E4OD 155000 miles, EEC ignition and I live in the mountains at 7000 ft. Everytime I travel to lower elevations the truck runs bad( loss of power sputtering when taking off from a stop or when giving it gas). I was wonding if this could be the MAP sensor, there are no codes stored in the computer. Is there a way to test it or just spend the $85.00 and try a new one. Also do the code checkers that cost around $45.00 and just blink and you count the codes worth the money?
Old Jun 15, 2002 | 05:37 AM
cajunbronco's Avatar
cajunbronco
MAP Sensor
I would'nt waste my money on the cheap code reader.You can do the same thing by jumping the diagnostic test connector leads and it will flash out codes on the check engine light.Do a search on the net for ford trouble or eec codes.There are several sites that how you how to do it.As for the map you can test it with a voltmeter and a vacuum pump.A haynes manual will describe the procedure.For a quick check,if the engine is running unplug the map it should kill the engine.
Billy
Old Jun 25, 2002 | 12:04 PM
steve4413's Avatar
steve4413
MAP Sensor
Next time you have this problem try turning the key off and restarting. This resets the map sensor to the altitude that you are at.
Old Jun 26, 2002 | 01:17 PM
winfordr's Avatar
winfordr
MAP Sensor
I agree with cajunbronco. The MAP sensor only works at startup. It produces a varying FREQUENCY signal depending on atmospheric pressure. I would use a set of sensitive headphones and vacuum source to test it.
Winford
Old Jun 27, 2002 | 09:18 AM
Lightning2Fast's Avatar
Lightning2Fast
MAP Sensor
the map sensor does NOT only work at startup. it has a function whenever the engine is running. it is the major load sensor. this is why it has a vacuum line connected to it. as load increases vacuum drops. this the map then sends a signal in hz to the pcm. the pcm then delivers the correct amount fuel by manipulating the injector pulse. this is a nutshell explanation of course. the pcm also monitors t/p and 02 readings to determine the engines actual load. this is why when you unplug the map at idle the engine stalls. the pcm thinks there is no engine vacuum and dump large amounts of fuel into the engine. it just gets too rich to run and it stalls. also this is why speed density doesnt get along too well with aftermarket cams. the vacuum at idle is not high enough. the pcm creates a rich condition and now you can barely get the truck to idle.
Old Jun 27, 2002 | 12:16 PM
winfordr's Avatar
winfordr
MAP Sensor
I stand corrected. I confused the MAP sensor with the BP sensor, which is basically the same device, but does not have manifold vacuum connected. It is the one which senses barometric pressure, and is used on mass-air systems.
Sorry for the mixup.
Winford
Old Jun 27, 2002 | 05:14 PM
Lightning2Fast
MAP Sensor
youre exactly right winford!
Old Jun 28, 2002 | 10:14 AM
timberbuck's Avatar
timberbuck
MAP Sensor
ChrisAU
Mar 9, 2013 03:37 PM
mwstan
Dec 28, 2012 12:27 AM
pjnadon
Jan 22, 2011 10:01 PM
dlburch
Jan 12, 2008 10:47 PM
87ford
Sep 28, 2006 05:49 PM
