egr,map,tps?
Old Sep 28, 2006 | 12:14 AM
87ford's Avatar
87ford
egr,map,tps?
what would cause the plug to the egr,map sensor and throttle position sensor to make dull illumination on a test light? i changed the plugs them selves ( such as when you change an alternator sometimes you need to change the plug too) and the sensors but the problem is still their and with obd it throws the codes for the egr,map sensor, and throttle position?
Old Sep 28, 2006 | 05:40 AM
meck1's Avatar
meck1
Are you getting the illumination when the key is on? Or when it is off? Also, on which colored wire of the plug are you getting the illumination? And what are you grounding the test lamp to? Since the items mentioned (egr etc.) all work off of a constant 5 volts from the ECM (computer), that would probably make for a low illumination. That would occur only with the key on, though.
Old Sep 28, 2006 | 05:49 PM
87ford's Avatar
87ford
alright so if the dull illumination is normal then thats cool..
fenwick
18
Aug 19, 2014 04:23 PM
mwbrownsr
1978 - 1996 Big Bronco
Mar 11, 2010 06:06 PM
FTK560
4 Cylinder Engines
Mar 28, 2005 01:35 PM
Jmackenroth
Oct 5, 2004 07:46 PM
302FROGMAN
Feb 6, 2003 09:20 PM
