WYD? Fix OEM or Replace Stereo
the one thing i noticed about my pioneers is the supertuner in the new ones doesnt tune in stations as good as the old ones, and the ones with oled displays burn out after years. i have one i payed 500$ for back in the day when it was top dog, now i cant use it because its oled display isnt visable, really ticks me off since i spent hundreds more on all the specific IPBUS assessories for it..
dose this set up sound for a 5 chanel radio setup?
- Kenwood DNN990HD eXcelon WiFi-Embedded In-Dash Receiver
- Kenwood XR900-5 eXeclon 5-Channel Power Amplifier
- Kenwood Excelon KFC-X683C 6 x 8 Inch 2 Way Pair Of Car Speakers Totalling 360 Watts Peak / 120 Watts RMS
- Kenwood eXcelon KFC-XW1000F Woofer - 250 W RMS/1200 W PMPO
- Sycho Sound New Single Car Truck Wedge Black Subwoofer Box Sealed Enclosure for 10-Inch Woofer 10F
Now you're talking, that'll put the Jensen to shame, don't forget you'll also need an installation kit, some harness adapters to adapt the factory wiring to aftermarket, and if you have steering wheel controls there's also products that adapt those to use with an aftermarket system, you can find these here: iPod Integration for your car and More by Pac-Audio - Connecting you to the future Metra Online | Welcome to Metra Auto Parts Online Warehouse What year of truck are you installing this in anyway ?
so question is since i mainly listen to siriusxm. would a oem radio with cd changer controlls so i can get a aux in adapter. or a sped a lot more to get a modern radio with nav and built in siriusxm and bluetooth calling
You can't see it but my OEM one above is sat radio ready. But you have to have an antenna sat radio.
looks like its bolt in too with out side clips like the truck will have.
ok thats what i was thinking. probly easyer to find aftermarket then a oem wth cd, mp3, rds, and cd controll for a aux in adapter for my siriusxm edge. i could also get nav with new radio
I am running a Sony. They sound good and have an easy to use layout. Presets, menus, adjustments and etc are easy to do without reading the instructions. They also put front mounted USB and AUX ports on a lot of their units which I like.
this is a wishlist on crutchfield for a radio and accessories to be a good start i figure.
GamerGirlAlice's Wishlist
You can get sirius/xm for the Kenwood system you're looking at but it requires the optional SXV200 Tuner that connects to the Kenwood. You may have to do some modifications to the dash on your 99 to get this double DIN Kenwood to fit.
its the organic led displays that are the problem, it might have to do with the extreem low temps here maybe -20f i dont know. but i know its out and seems to be a common problem on the google search.
