56' radiator mount help
Old Oct 11, 2013 | 09:34 AM
ohbrian's Avatar
ohbrian
I ordered a new radiator and I'm having an issue mounting it because whoever installed the last one removed a piece to make it fit. The piece circled in the picture below n(shamelessly stolen from an ebay ad). I can't tell how that piece was connected...I wonder if I should attempt to get another one...or just put some metal straps on that side.
Old Oct 11, 2013 | 09:39 AM
yamagrant's Avatar
yamagrant
that's part of the frame. You will need to make on and weld it up. Good luck with your build.
Old Oct 11, 2013 | 09:48 AM
ohbrian's Avatar
ohbrian
I just found on mid fifty they sell the whole "Radiator Saddle" for 170 bucks...I need to find someone who can weld...
Old Oct 11, 2013 | 12:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B3C-16138-B .. Radiator Support / Obsolete
1953/56 F100/900 all I-6 & V8 engines.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 17 = 800-476-9653.
Old Oct 11, 2013 | 06:46 PM
fordman75's Avatar
fordman75
Those brackets were rivoted to the radiator mount/support. Your best bet is to find a used one.
Where are you located? I've got a couple radiator mounts/supports laying around that might have the bracket you need. And did your truck have a V8 or a 6cyl stock. I might be wrong but I believe the 6cyl ones were different.
Old Oct 11, 2013 | 07:14 PM
ohbrian's Avatar
ohbrian
I'm in California. I think when I looked up the vin it said it had a 272? The radiator I ordered didn't ask for v6 or v8 so I assumed they were the same. it would fit perfect if I had the missing piece. I'll paypal you some cash and shipping if you've got one...
Old Oct 11, 2013 | 07:27 PM
fordman75's Avatar
fordman75
I'll dig out the radiator mounts/supports I've got this weekend. And will check and see if the mounting brackets are ok.
Old Oct 11, 2013 | 08:29 PM
NumberDummy
No V6 in an F100 until 1982. Fordman75 is referring to the 223 I-6 which was standard equipment in 1954/56's.
Radiator support is the SAME: 1953/56 F100/900 215/223 I-6 & and all V8's. See post 4.
Old Oct 12, 2013 | 12:34 PM
Cabledude's Avatar
Cabledude
When I got started on my 54 F250 the radiator had been removed. It did not have the crossbars I noticed in the picture. Mine has the inline 6. Does anyone know if they all had the cross pieces, if so I would like to put them in to make it look original, not that anyone else would probably notice.
Old Oct 12, 2013 | 05:07 PM
fordman75's Avatar
fordman75
I might be wrong but I don't think they started using the cross bars until 55.
Old Oct 13, 2013 | 11:23 AM
Project-55's Avatar
Project-55
I will look at the radiator supports I just took off of my core support, if they are still useable to can have them. Hopefully I didn't beat them up too bad.
I'll check today and get back to you this evening.
Gary
Old Oct 13, 2013 | 12:18 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Ohbrian,
CA is a big long state, more info would help. If you are in the north I can weld it for you if you end up needing it welded. I will look to see if I still have mine as I took them off for a custom radiator set-up, no promises as it was a few years ago.
Old Oct 13, 2013 | 12:48 PM
ohbrian's Avatar
ohbrian
Oh sorry about that, I live in Tracy, kinda far from you...
Old Oct 13, 2013 | 01:03 PM
truckeemtnfords
As stated they were riveted so you can always bolt it. Other wise if you go skiing bring your parts.
Old Oct 13, 2013 | 02:38 PM
Project-55's Avatar
Project-55
I checked my scrap pile and you are in luck, I have both radiator mounts. They were originally riveted in top and bottom with a couple of spot welds in the center area but they can be bolted back in without a problem.
If you want them just give me a PM with your address, all you need to do is pay the shipping.
Gary
