1965 vin decod
Old Oct 10, 2013 | 08:04 PM
madman1966's Avatar
madman1966
1965 vin decod
warinty number f25dr673209 w.b 129 color m model f250 body d81 trans n axle 24 maxg.v.w. lbs 7500 cert.net hp 172 r.p.m 4000 and then 72 but cant read last numbers ples inform of what it all means
Old Oct 11, 2013 | 03:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by madman1966
F25DR673209 / W.B. 129 / COLOR: M / MODEL: F250 / BODY: D81 / TRANS: N / AXLE: 24 / MAX GVW LBS: 7500 / CERT NET HP: 172 / RPM: 4000 / DSO: 72
F25 = F250 2WD
D = 352 2V
R = San Jose CA Assembly Plant.
673209 = 1965, assembled April 1965.
129" Wheelbase.
M = Wimbledon White.
F250 2WD, 7,500 lbs. GVWR
D81: D = Light Beige Crush Vinyl & Medium Beige Ladder Pattern Woven Plastic / 81 = 81B Custom Cab.
N = New Process 435 4 Speed Manual Transmission.
24 = Spicer/Dana 60 Rear Axle / 4.10-1 / No Limited Slip / 5,200 lbs. Rear Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Oct 11, 2013 | 06:12 PM
madman1966's Avatar
madman1966
i dint see eney other numbers after the 72
Old Oct 11, 2013 | 06:34 PM
madman1966's Avatar
madman1966
and how come the trans has a tag saying only limited slip diff flued if it a no limited slip
Old Oct 11, 2013 | 07:57 PM
NumberDummy
and how come the trans has a tag saying only limited slip diff fluid if it a no limited slip
There is no such thing as Limited Slip fluid. Trans ID tag has no reference of any kind inre to rear axle fluid.
When Limited Slip is present, 4 ounces of friction modifier is added to the rear axles 90 weight gear lube.
Here's a pic of the New Process 435 4 speed TRANS ID tag. Do you see any reference to fluid? No and I don't either.
Old Oct 12, 2013 | 03:40 PM
madman1966's Avatar
madman1966
i dint mean on the tran i was refering to the one on the rear diff
Old Oct 12, 2013 | 05:17 PM
Roger Carter's Avatar
Roger Carter
Maybe some form of a limited slip was installed after the truck was sold and the tag was added at that time.
Roger Carter
Old Oct 12, 2013 | 08:09 PM
NumberDummy
1965 F250 AXLE code 24: Spicer/Dana 60 4.10-1 without Limited Slip.
1965 F250 AXLE code B4: Spicer/Dana 60 4.10-1 with Limited Slip.
1959 thru today: If the AXLE code begins w/a letter: Limited Slip / If with a number: No Limited Slip.
2nd pic: Spicer/Dana 44/60/60.2/60.3/70 parts catalog example of rear axle tag & Limited Slip tag:
Old Oct 13, 2013 | 10:49 AM
Roger Carter
In our trucks with the Dana 60 rear axle, the most common limited slip is a Spcer Power-Lok. Today there are other units for the 60, but from the time the trucks were new up into the late '70s and early '80s the Power-Lok was king. The Power-Lok is the unit your truck would have come with, if it had been a factory install, or if a dealer had converted it "back in the day".
A quick way to see if your rear axle might be a Power-Lok is to pull the rear avle fill plug and take a peek inside. A factory non limited slip (open) carrier is cast steel and you will see the natural cast surface of the carrier. A Power-Lok, and possibly other types of limited slips, has a machined carrier. When looking through the fill plug opening you will see a smooth, bright, machined surface.
You may need to lift both rear tires and have someone turn one of them to posistion the carrier so it can be seen through the fill opening.
As long as you have the truck in the air and are spinning a tire (by hand), check the other tire. If it is spinning the same direction as the one you are spinning, grab it. If you can't stop it you have a limited slip. If it stops either your limited slip isn't working or you have an open differential. If the second tire spins the opposite direction as the one you are turning you have an open differential.
Roger Carter
Old Oct 13, 2013 | 12:54 PM
NumberDummy
Don't know how much one could see peering thru that tiny fill plug hole. Removing the inspection cover will give a far greater view.
"Locking" refers to Power-Lok aka Limited Slip.
Old Oct 13, 2013 | 02:01 PM
Roger Carter
You can see the difference between a cast surface and a machined surface..
Roger Carter
Old Oct 14, 2013 | 11:18 AM
madman1966's Avatar
madman1966
number the pick with the dif with 2 tags is what mine looks like and it in about as bad a shap as the cast tag so that y i belev it is a origanal thing so is it likly that the dealer had it canged befor the origanal sale
Amphihauler
Aug 26, 2016 01:53 PM
mrgoob
Sep 23, 2012 07:52 AM
mrgoob
Sep 22, 2012 12:27 PM
cheddar89
Mar 8, 2012 09:13 AM
69ranger250
Jan 21, 2009 01:55 PM
