Dash Removal-Ongoing IVS Issue-Help!!!
Old Oct 11, 2013 | 10:47 AM
BBslider001's Avatar
BBslider001
Originally Posted by DIYMechanic
I have removed a couple of these dashes, but it's been a while. As best I can recall, you pull the steering column (which is a lot easier than you might think). Then you take all the screws out that are up along the base of the windshield, take the bolts out of the big aluminum bracket on the driver side, there are 1 or 2 bolts in a couple of lateral braces underneath and 1 or 2 on the passenger side. Then it starts to come loose and you just have to unhook a few wiring, vacuum and cable connections behind the dash. It's really not all that bad as I recall. It took me a long time the first time, but the second time I did it I want to say it took me less than an hour to have it out.
You may want to trim out the insulation around where the big aluminum bracket bolts to the firewall, but aside from that I don't see why not. One thing I do recommend though is that you take 10 minutes before you start and remove the front seats. Having those out of the way makes this 10 times easier.
Nate, this is good info.Thanks! I think I may have averted removing the dash just yet. I am going to replace the wires where they connect at the fusebox and the PCM with new pieces and then see what results I get. I have to see how easy it is to get to the #5 pin on the PCM first and that will answer my question. I checked the #3 fuse wire this morning and it just OK, but not great. Fuse is not blown, so that eliminates that possibility. I still believe it is the main wire loom and that would require removing everything. I hope I don't have to, but if I do, lots of pics and a write up!
Old Oct 11, 2013 | 10:53 AM
DIYMechanic's Avatar
DIYMechanic
Before y ou start running new wires, I would test for voltage at the IVS when this happens. If you have voltage at neither wire, your issue is between the IVS and the fuse block. If you have voltage on one wire and not the other when the pedal is depressed, you have a bad IVS. If you have voltage at both wires when the pedal is depressed, then your issue is between the IVS and the PCM. It would at least give you a direction to start in.
Old Oct 11, 2013 | 11:31 AM
BBslider001
This helps a lot. Thanks! I am pretty sure it won't be the IVS. I have two. One is brand new and one is the original and it does it with both of them. Also, wouldn't moving the wires around enough to get it to work tell me it's a wiring issue? I so wish it was just the switch. That would be an easy easy repair.
Old Oct 11, 2013 | 11:52 AM
madpogue's Avatar
madpogue
True, but Nate's idea is to narrow down WHICH wire is bad. First thing to test would be the brown wire. Wait 'til "it happens", then put a voltmeter on the brown wire terminal at the switch. If no voltage, keep the meter on it and jiggle the wires as you've been doing. See if the voltmeter eventually responds and the CE light goes off at the same time. If so, that fingers the brown wire from the fuse box.
If there _is_ voltage when you first check it, that brown wire is _probably_ good, and the red/orange wire from the switch to the PCM is probably the bad one. At that point, you'd want to do a continuity check (which would be tricky, would require some extension wire) between the red/orange wire terminal at the switch, and pin 5 at the PCM. Most likely it will show "open", infinite resistance, no continuity. Again, jiggle the wires and watch the meter, see if it eventually shows continuity / zero (or very low) resistance. That would implicate that that's the faulty wire.
Old Oct 11, 2013 | 12:18 PM
BBslider001
Gotcha. That makes sense. I need to get a more simple voltmeter today. the ones we have at work are the $500 kind with infinite ways to test and I am not even sure if I have selected the right setting when using it before. Like I have said, I am a total rookie when it comes to electrical. Again, thanks so much for the education. I don't feel near as stressed as I did yesterday when I was trying to solve the issue. A little knowledge goes a long way.
Old Oct 15, 2013 | 11:37 AM
BBslider001
Well, I am going to be tackling this today. I am going to test the wires,but something is telling me it is the red/orange wire going to the PCM. The brown wire to the #3 fuse does not need to be touched. If I wiggle the R/O wire, I can get it to work. AS long as I leave it running, I have no problems. That also leads me to believe it is that wire because it acting like when you click the IVS one time to tell the PCM to open the throttle. Wiggling it makes it tell the PCM that the throttle is ready (my IVS is relocated under the dash). I hope this makes sense? I will verify this with my nice, new inexpensive volt meter.
So, my next question, since I am believing that wire is the culprit, what happens when I unplug the PCM? It has to relearn all of the perimeters when I plug it back in, correct? What should I expect behavior-wise from the truck when I get it all back together, assuming the issue is fixed? Will it start and run? Will it shift normally? Do I have to drive it for a few miles to let it set itself?
Old Oct 15, 2013 | 11:51 AM
DarkStarMedia's Avatar
DarkStarMedia
The PCM in our trucks on not adaptive or "learning"
Richard
Old Oct 15, 2013 | 12:11 PM
DIYMechanic
What do you mean the IVS is relocated?
And yeah, what Richard said. The only thing the PCM "learns" is supposedly what rear end ratio you have, and even that is up for debate. The PCM really suffers no ill effects from being unhooked.
Old Oct 15, 2013 | 12:27 PM
oldbird1965's Avatar
oldbird1965
The SD's PCM is a 'learning' PCM, not ours.
Old Oct 15, 2013 | 01:13 PM
BBslider001
Richard
Got it. Thanks!
Nate, I don't know if you remember, but I relocated the IVS under my dash and it fixed the jumpy throttle. I did it back when i was having major issues with the TPS and dead throttle. Rather than try the pedal mod and bending the tab, I read another thread where it was removed from the pedal and relocated under the dash or wherever one wants to put it. Throttle is WAY smoother. You have to click it once, after starting the truck, to tell the PCM to engage throttle from the TPS. I can put it back on the pedal if needed, but that isn't an issue and has been much more driver friendly.
See here if you have time:
https://www.ford-trucks.com/forums/1...-question.html
Thanks Glenn! helps quite a bit!
Old Oct 15, 2013 | 02:35 PM
DIYMechanic
Got it. Thanks!
I remember now. Got it.
Old Oct 15, 2013 | 03:25 PM
madpogue's Avatar
madpogue
Now that you've identified the IVS issue as a wiring issue, when you get it resolved, it would be a good idea to repatriate it back to the pedal, where it was designed to operate. But cross that bridge when you get to it.... (crossing fingers that your wiring fix works...)
Old Oct 17, 2013 | 11:44 AM
  #28
BBslider001
I dunno...the driveability has been so much nicer. Especially with 10k hooked to it, it doesn't do the herky-jerky thing with the throttle now. I will probably leave it like it is . Crossing my fingers as well. Bought a new volt meter. My other one went haywire on me. Gonna tackle this today and hopefully get it worked out.
Old Oct 17, 2013 | 12:09 PM
  #29
BBslider001
Ok, I must be pretty dumb. I am not getting this testing at all. When I test my batteries just to make sure I am getting a good reading, I am getting 27 on the LED screen on my meter. When I test the brown wire at the pigtail, I get a reading of 27 with pedal depressed or idle. I have not tested the R/O yet. I have to get to the pin to do so. I am such a rookie at this electrical stuff. Continuity versus ohms versus voltages is making my all crazy. Any help or direction would be so appreciated. I did do what was described to me to do, but just got the reading of 27.
Old Oct 17, 2013 | 12:26 PM
  #30
BBslider001
Ok, now I am seriously confused. There are 3 wiring harness on the drivers side firewall, but only 2 under the dash! What I thought was the PCM I am not even sure about now. The harness on the FW closest to the outside looks to be the PCM, but where does it come into the truck under the dash? I would post a photo, but I am not at home yet.
