$400 for repairs
Old Oct 9, 2013 | 11:45 PM
thomich1353's Avatar
thomich1353
$400 for repairs
hi all
i got a 1995 F150 ext cab 3" suspension lift 5.8L V8 4wd. i have $400 to spend on my truck alone and was curious if any one had any ideas as to what i can spend it on that will be the most beneficial and why. and if possible spread the "wealth " through out a few things not just one.
Thanks for your help
TJ
Old Oct 10, 2013 | 02:11 AM
kermmydog's Avatar
kermmydog
Save it for a rainy day.
Old Oct 10, 2013 | 02:30 AM
Evan_P's Avatar
Evan_P
Save it for when something breaks. No need to spend money if there is nothing wrong.
Old Oct 10, 2013 | 07:42 AM
garthneddy's Avatar
garthneddy
Check all the common wear items, I'm sure you will find something that either needs replaced or is getting close.
If you live in the rust belt, check all suspension and body mounts. These trucks are known for falling apart dues to rust up here.
Old Oct 10, 2013 | 10:14 AM
BigBlockF350's Avatar
BigBlockF350
If nothing is broken, don't throw too much money at it yet. It may come in handy when something actually does break unexpectedly.
If you want to do something fairly cheap though, grease all of grease-able fittings. Tie rod ends, ball joints, u-joints. These may not all be the grease able types, but you can grease whatever will take it. This is very good preventative maintenance.
You could also check out your brakes. We're headed into winter, so you may want to make sure your brakes are in good order. Check out your pads/rotors in the front, and adjust the rear drums (free), and your rubber brake hoses. Maybe bleed new fluid through the system if it's dark/old and you feel that it needs it. You won't even get near your $400 here, and it's good regular maintenance.
Old Oct 10, 2013 | 10:30 AM
Jaime74656's Avatar
Jaime74656
personially heres what I would (and do) do in your case...
If it ain't broke, I ain't a fixin' it, and save the $400 for a rainy day and while saving the $400 every so often (assumeing your work or have a job of some type) put a few dollars ($20 - $40) away in the "truck fund" and build up more $$$ that way...I do this and it works....when I don't have massive repairs to do
Old Oct 10, 2013 | 05:08 PM
thomich1353
Thanks everyone but i got one question you all may be able to help me with.
when my hubs are in the free position may truck drives just fine but when i lock my hubs it makes a grinding and knocking sound. my question is do i need to replace the wheel bearing/ hub assembly or just the lockout hubs?
Old Oct 10, 2013 | 05:43 PM
bashby's Avatar
bashby
Check your u joints in the front axle and driveshaft. See if it also makes noise with the transfer case in 4hi and hubs unlocked.
Old Oct 10, 2013 | 06:20 PM
thomich1353
it grinds when its in 4hi but I'm not sure where the sound is coming from i just here it in the cab com in from somewhere
Old Oct 11, 2013 | 12:06 AM
BigBlockF350
As has been said, cheap the front axle U-joints for play. They can make an awful racket if they're really worn out or if someone put in the wrong size. It's an easy place to start.
BroncoKing1995
Feb 26, 2012 09:10 AM
78F150classic
Sep 12, 2007 09:36 AM
tjbeggs
Jan 5, 2007 07:20 PM
kettle-one
Dec 31, 2005 10:21 AM
frnkln2003
Sep 18, 2004 10:04 PM
