Sponsored by: Real Truck
Hello All....
Old Oct 9, 2013 | 08:45 PM
tanks95's Avatar
tanks95
Hello All....
New Guy here, my name is William.
i am looking at getting a used 2008 F250 work truck. No frills no thrills, 2 door, plane jane. I have my eye on an manual trans 2008, with 45k.
Test drive went well, is there anything special i need to know?
*or point me in the right direction to the dumb new guy asking questions that have been asked too many times thread?
Thanks in advance.
William
Old Oct 9, 2013 | 10:24 PM
madsonp's Avatar
madsonp
Hello William, welcome to FTE.
Old Oct 9, 2013 | 10:47 PM
tanks95's Avatar
tanks95
Hello. Thanks for the welcome. Just poking around for info on my hopefully new to me 2008 F250.
Old Oct 10, 2013 | 06:02 AM
Fastfwd's Avatar
Fastfwd
If it's a diesel engine you will want to read up on common problems and how to prevent/fix them.
Old Oct 10, 2013 | 06:07 AM
redford's Avatar
redford
FTE Leadership Emeritus
Hello tanks95 and welcome to FTE.
What engine/transmission combination are you looking at? Also, look at the door sticker. When was the truck built, and what are the axle codes?
As for buying a used truck, make sure it has LOAD RANGE E tires on it. A lot of sellers will throw new LOAD RANGE D or lighter tires on the trucks when they are selling them, to save a few $$$$.
Old Oct 10, 2013 | 06:08 AM
senix's Avatar
senix
welcome to FTE, type of motor would be helpful. Pics are always great as well!
Old Oct 10, 2013 | 06:31 AM
tanks95's Avatar
tanks95
It's a gas, 5.4l, 6 speed, 4x2, regular cab, vinyl interior.
I don't know the door codes, I'll look the next time I see it.
Thanks gents.
Old Oct 10, 2013 | 06:36 AM
senix's Avatar
senix
If this is 4x4, then ensure the system works well. Also if it is shift on the fly go out and manually turn the hubs and make sure they turn freely.
I'd be check the front brakes to ensure they are ok. Backs would not hurt as well.
Normal fluid checks and if the owner is not around or lets you take the truck for a few, doing a little towing with it is good too.
Old Oct 10, 2013 | 06:41 AM
tanks95's Avatar
tanks95
Good Stuff, thanks
William
Old Oct 10, 2013 | 06:47 AM
redford's Avatar
redford
There may be a slight issue with the engine. On removal, the factory spark plugs might break. It is only an issue if your truck was built before 10/9/07. It does not affect driveability.
You can read the TSB here: https://www.ford-trucks.com/tsb/full...php?tsb=08-7-6
Otherwise, the truck is pretty bulletproof.
Old Oct 10, 2013 | 07:21 AM
tanks95's Avatar
tanks95
You can read the TSB here: 08-7-6*** SPARK PLUG REMOVAL INSTRUCTIONS - 4.6L 3V/5.4L 3V/6.8L 3V
The ceramic portion of the plug? Okay, good to know. I've been twisting wrenches for a few years, so hopefully that will not present a huge problem.
Also, i believe the owner does have the lower range tires on the truck, but ill use that a bargaining leverage, if my assumption is correct.
Good stuff
William
Old Oct 11, 2013 | 12:56 AM
tanks95's Avatar
tanks95
proposed purchase...
<a href="http://www.flickr.com/photos/wt_wallace/10202202604/" title="road side by Wt_Wallace, on Flickr"><img src="http://farm3.staticflickr.com/2826/10202202604_0dc255fc27_b.jpg" width="700" height="525" alt="road side"></a>
<a href="http://www.flickr.com/photos/wt_wallace/10202301915/" title="motor bay by Wt_Wallace, on Flickr"><img src="http://farm8.staticflickr.com/7390/10202301915_d527469e46_b.jpg" width="700" height="525" alt="motor bay"></a>
<a href="http://www.flickr.com/photos/wt_wallace/10202302045/" title="interior2 by Wt_Wallace, on Flickr"><img src="http://farm8.staticflickr.com/7391/10202302045_f662362db0_b.jpg" width="700" height="525" alt="interior2"></a>
<a href="http://www.flickr.com/photos/wt_wallace/10202391833/" title="interior by Wt_Wallace, on Flickr"><img src="http://farm6.staticflickr.com/5489/10202391833_31982855d0_b.jpg" width="700" height="525" alt="interior"></a>
<a href="http://www.flickr.com/photos/wt_wallace/10202202994/" title="curb side by Wt_Wallace, on Flickr"><img src="http://farm8.staticflickr.com/7321/10202202994_a328e0ac1c_b.jpg" width="700" height="525" alt="curb side"></a>
Old Oct 11, 2013 | 05:42 AM
redford's Avatar
redford
Sweet. Let us know how it comes out.
Old Oct 11, 2013 | 05:47 AM
senix's Avatar
senix
don't think you can go wrong with that truck. looks really good.
Old Oct 11, 2013 | 06:53 AM
tanks95's Avatar
tanks95
Will do
Hope so, test drive soon
