Fuel Delivery Problem
Old Jun 19, 2003 | 11:37 AM
A-Muck Truck's Avatar
A-Muck Truck
Have an '89 F-350 SRW / 460ci. with dual tanks. The rear tank is relativly new with new pump, hardware and such. The rear tank gauge dosen't work properly. The front tank is original and leaks. I had a plugged fuel filter and changed that.
Problem:
With a full rear tank, I drive a few miles and suddenly no fuel delivery. Both gas caps are fine. Switch over to the front tank and no problem. Drive for awhile and switch back to the rear tank, no problem. Drive a few more miles and suddenly no fuel delivery. Repeat the cycle. There is a persistant smell of fuel although no leaks have been detected. Fuel consumption is up dramatically but no leaks.
Is this a vapor return line/vapor cannister problem ? Is it a tank switch or electrical problem ? Any help appreciated before I start replacing things. Thank you.
Old Jun 19, 2003 | 12:34 PM
steve83's Avatar
steve83
Don't replace anything until you know what's wrong. Throwing money at it rarely helps.
Check the fuel pressure at the fuel rail when you have "suddenly no fuel delivery", and also the voltage at the rear fuel pump (the Haynes wiring diagrams show which wires).
Milpool
Sep 6, 2016 08:37 AM
Rigby
Jul 2, 2016 11:17 AM
Nothing Special
Nov 12, 2013 06:54 AM
J and J
Apr 28, 2011 05:29 PM
Traderjoe28
Sep 29, 2004 03:35 PM
