351m transmission compatibility
Old Oct 9, 2013 | 01:13 AM
shane_lxi's Avatar
shane_lxi
My newly acquired 77 F150 with a 351M has a leaky slipping transmission. It works, but I don't know for how long. My cousin has a transmission that came off a 400 (I believe he said a Mercury Cougar, but I could be wrong). Would that fit? He said it was recently rebuilt and I could just have it, so that would be really nice! Any help is appreciated! Sorry, I am very new to Fords
Old Oct 9, 2013 | 03:58 AM
slashfan7964's Avatar
slashfan7964
Ask him what transmission it is. The 351M takes a big block bell housing. 429/460 etc works. It has to have a big block bell housing. If you get that it should be fine.
Distributors are the same too IIRC.
Old Oct 9, 2013 | 04:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Only A/T available in 1977/79 F100/350, 1978/82 Bronco & 1980/82 F150/350 with 351M/400: C6 (17 trans pan bolt holes).
Some 1974/79 Cougar's with 400's, 1975/79's with 351M's came with C6's, while some came with FMX's (14 trans pan bolt holes).
This C6/FMX jazz also applies to 1973/76 Torino/Montego; 1973/79 Ranchero; 1977/79 LTD II (not an LTD!)/Thunderbird/Mark V cuz that's what a 1974/79 Cougar is...under the skin.
Old Oct 9, 2013 | 04:35 AM
slashfan7964
Both the 351M & 400 used the same C6.
He never specified if it was an auto or a manual. Either way it requires a big block bell housing.
Old Oct 9, 2013 | 05:00 AM
tjc transport's Avatar
tjc transport
i ain't rite
but since both the 351M and 400 use the same bolt pattern, specifying "it has to be a big block bell housing " is a moot point.
and ford never made a "big block" that is a chevy thing.
Old Oct 9, 2013 | 05:05 AM
NumberDummy
Wanna bet?!
What type of trans do you think the OP was referring to when he typed this?
OP said he believes his cousin said the 400 trans came from a Mercury Cougar.
How many Passenger Cars with 351M/400's came with a M/T? None!
And btw: Bell Housing: M/T / Converter Housing: A/T
The C6 doesn't have a separate converter housing, as it's made as part of the transmission case.
Old Oct 9, 2013 | 02:02 PM
shane_lxi's Avatar
shane_lxi
Thanks guys, I'll go check it out and see if it's a c6. If it is, i'll ****** it up!
Quaranta
18
Mar 4, 2018 05:09 PM
Rollin'in'79
Jul 29, 2016 02:32 AM
captain1997
Sep 28, 2012 01:21 PM
flaireside95
1978 - 1996 Big Bronco
Feb 20, 2004 07:15 AM
clint69
Jan 4, 2001 05:03 PM
