Introducing the 77’! - Ford Truck Enthusiasts Forums
Old 02-13-2018, 07:28 PM
Quaranta's Avatar
Quaranta
Quaranta is offline
Quaranta is starting off with a positive reputation.
Hey everyone! Wanted to introduce myself and the 77’ F100 I picked up today. Needs a transmission and rearend, but I snagged it for $600. If anyone in the Tulsa area knows of a c6 for sale that will bolt to the 351m let me know.
Old 02-13-2018, 07:44 PM
Jacob Bowman's Avatar
Jacob Bowman
Jacob Bowman is offline
Jacob Bowman is starting off with a positive reputation.
I’m still a little new to the scene here on dent side trucks, but I believe a 351m uses the smallblock bell housing meaning it will accept a c6 from a 300, 302, or 351 not sure about other things like flex plate fitment or etc.
Old 02-13-2018, 08:09 PM
77highboy77
77highboy77 is offline
77highboy77 is starting off with a positive reputation.
Nope, 351m's use the same bell housing as the 400, 429, 460.
Old 02-13-2018, 08:10 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
PA74F250 is starting off with a positive reputation.
351m uses big block pattern not small.
Quaranta's Avatar
Quaranta
Quaranta is offline
well that’s a good start! Now I just need to find one and learn how to rebuild it using the dvd series everyone has talked about on here.
Old 02-13-2018, 08:17 PM
mihnen
mihnen is offline
mihnen is starting off with a positive reputation.
Nice looking truck, congrats! The rims/tires look good, what size are those?
Old 02-13-2018, 08:20 PM
Quaranta's Avatar
Quaranta
Quaranta is offline
I have no idea... the truck is currently at my buddies shop a few miles away. But I will find out.
Old 02-13-2018, 08:21 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
Welcome to FTE Quaranta, and correct a 351M will bolt to a BIG block auto trans pattern ONLY.
Did you match the paper title vi# with the dvrs door riveted on Warranty Plate #, and the B pillar Safety Certification white sticker #, AND the frame vi#? Because that front grill looks like a 73...
Make sure you join your FTE Oklahoma chapter to get a lead on in state parts.
https://www.ford-trucks.com/forums/forum92/
Old 02-13-2018, 08:22 PM
Quaranta's Avatar
Quaranta
Quaranta is offline
Thats a good start... Now I just need to find one, and then grab the bad shoe productions rebuild dvd that everyone says is awesome.
Old 02-13-2018, 08:25 PM
Quaranta's Avatar
Quaranta
Quaranta is offline
I havent, but thanks for the tip. The title says 77 but I have not checked the vins. I went the route of blindly throwing over $600 because it seemed like a steal lol
Old 02-13-2018, 08:53 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
It is a steal, untill you find out you paid $600 for a title and a matching door, and the rest of the truck is stole....I am sure it will work out, just ck the #'s.
Old 02-13-2018, 08:59 PM
Jacob Bowman
Darn it, tried to teach myself that engines that start with 3 are small block and engines that start with 4 are big block. Guess 351 is also big block. Should’ve remembered that 400 is stroked 351 therefore they are the same engine block
Old 02-13-2018, 09:44 PM
meangreen92's Avatar
meangreen92
meangreen92 is offline
meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.
351 Cleveland and Windsor have the smaller bell patterns. The 351M and 400 were never put in anything smaller than a Torino Elite, and have the big block bell pattern.
I see the '73-'75 grills, but I also see F100 CUSTOM nomenclature on the cowl, and that indicates '77-'79. Still a good idear to see if the frame agrees. Does the fuel filler have a vanity door, or exposed cap?
Old 02-13-2018, 10:15 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Not to be confused with....
But remember....335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Make sure you check out the Performance, Engines & Troubleshooting link https://www.ford-trucks.com/forums/forum9/
Old 02-13-2018, 10:51 PM
Quaranta's Avatar
Quaranta
Quaranta is offline
So I have located a c6 from an 83’ f-350 with a 460. Will that fit my 351m?
Quick Reply: Introducing the 77’!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
