I checked fuse socket #23 to ground and got 35000ohms which means my flasher is bad but for the life of me can't find the flasher.
page 151-6 says it's under the dash and it operates the blower motor as well but the blower is working, just the turn signals and hazard is not working.
Where is that thing??
Update....looks like the "multifunction" switch, which has been on my mind for years since every time I use the wipers I experience issues while moving the tilt wheel so I'll replace the m.switch and see what happens.
Replaced the multifunction switch and the "blue" f65b-13350-aa relay, checked my fuses and my hazard and turn signals still don't work.
Blower works, wipers work. I checked the light bulbs and they where ok.
I was hooked up to a boat trailer with the hazard on and they stopped working after a couple of hours
This accured only after I hooked up to a "old" boat trailer 2005....
any thoughts?
