5 speed with 351C
Old 06-19-2003, 10:09 AM
blatherskite's Avatar
blatherskite
blatherskite is offline
5 speed with 351C
I would like to mate a late model T5 5-speed manual trans behind my 351 Cleveland that's going in my '51 F1 project. I know that I can get an adaptor for the older small block bellhousing but I was thinking it would be cleaner (and hopefully easier) to use the late model bellhousing/hydraulic clutch if possible.
Does anyone have some experience with this combo?? will it work?? What clutch/flywheel etc
Thanks for any help on this matter!!
Old 06-19-2003, 05:36 PM
Brian S's Avatar
Brian S
Brian S is offline
5 speed with 351C
it should swap just like a 5.0 motor.
http://www.geocities.com/MotorCity/D...66/5speed.html
A hydraulic clutch may involve some fabrication, I don't know anyone who makes a kit for the F1.
http://webpages.charter.net/tt4wd/ti...hydclutch.html
Old 06-19-2003, 06:12 PM
70fordguy's Avatar
70fordguy
70fordguy is offline
5 speed with 351C
Just my .02 but I would consider the following about T-5's.
1. A 351C is a lot more engine than a 302/5.0
2. Not all T-5 trannys were created equal, ther is a wide variation in torque ratings.
3. Any truck will weigh much more than the cars that came with T-5's ---refer to #2.
Old 06-24-2003, 10:24 AM
FX4ALL's Avatar
FX4ALL
FX4ALL is offline
5 speed with 351C
I don't know if this will help but,
mustangsunlimited , mustangsplus, texasmustang, dallasmustsang, CJponyparts, maybe Summit Racing sells conversion kits for late model mustangs. They might have parts for you project. If nothing else they do have the bellhousing and flywheel, clutch, cables and brackets etc.
Hope this helps
Old 06-24-2003, 04:36 PM
Brian S's Avatar
Brian S
Brian S is offline
5 speed with 351C
They are fine for an early Mustang with a 289 but consider a Tremec if you plan to abuse it much.
http://www.5speedtransmissions.com/
Old 06-25-2003, 07:18 AM
77 F100's Avatar
77 F100
77 F100 is offline
5 speed with 351C
I am considering a Tremec 3550 to go in my 77 F100, because on the ability to convert it to front or mid mount shifting, since I want to keep my bench seat.
On of the posters on another board that I ferquent (*********.org) said that he adapted a Mustang cable in a T5 conversion in his F100. I have also seen Hydraulic conversions, www.autoworks.cc
Another site that was mentioned in that post, detailed how to put an S10 tailshaft on an F body T5 to move the shifter forward.
www.inliners.org/Jack/T5tech.html
Old 06-26-2003, 12:34 AM
c_rossman's Avatar
c_rossman
c_rossman is offline
5 speed with 351C
A ZF-5 speed from a big block ford will work.
Old 04-27-2020, 11:01 AM
baddad457's Avatar
baddad457
baddad457 is offline
Originally Posted by skald
Hello, Anybody have any thought if a T5 trans will mate up with a 351 Cleveland with insignificant intricacies. Perhaps only an alternate size flywheel or ringer lodging?
Did it ever occur to you to start a new thread rather than resurrectling a 17 year old thread ?
Old 05-22-2021, 07:09 AM
therockguy's Avatar
therockguy
therockguy is offline
how dare he try to add to the information i was glad to find then sad to see died.
i was just looking at putting a zf5 off craigslist into my 72 ranchero... some extra gears would be handy....
The following users liked this post:
Old 05-22-2021, 08:00 AM
baddad457's Avatar
baddad457
And yet here you are resurrecting it again, answering my post after 13 months
Old 05-22-2021, 08:12 AM
therockguy's Avatar
therockguy
see ya again in a year or two, illl pop into this thread to mention something slightly related
Old 05-22-2021, 09:36 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
A spammer hit this thread and the post was quickly removed (as all spam posts are), this resulting chatter is just noise. Sorry for the interruption.
Old 05-22-2021, 09:44 AM
therockguy's Avatar
therockguy
no worries, i dont feel like you interrupted much, i forgive you 😝
Old 05-22-2021, 05:06 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,671 Likes on 1,364 Posts
I think you will find the top of the ZF will double as a console in your Ranchero.....
Old 05-22-2021, 05:10 PM
therockguy's Avatar
therockguy
oh hell yeah, and like a normal shifter lever length, so i can put a massive shifting ball at like eye height.
Lets do it!
Quick Reply: 5 speed with 351C
