Power Steering Breakdown - DIAGNOSIS NEEDED!
Old Oct 7, 2013 | 05:59 PM
spindlebox's Avatar
spindlebox
Exclamation Power Steering Breakdown - DIAGNOSIS NEEDED!
So, I pull out of a parking lot tonight and turn my wheel to the right, and feel it "give way", the wheel totally kept going to the right and then it became really hard to steer.
I was able to drive home, with it being very hard to steer and lots of belt noise.
The belt appeared to be fine upon popping the hood, and there is power steering fluid in the reservoir and no leaking.
What do you think went out on me?
Please help with a diagnosis!
Scott
Old Oct 8, 2013 | 02:39 AM
Cobra-Kai's Avatar
Cobra-Kai
Remove the belt and turn the steering pump by hand
The belt squeeking could be a jammed pump.
If the pump wheel is hard to spin, the pump is broken
Old Oct 8, 2013 | 07:54 AM
spindlebox's Avatar
spindlebox
Cool! I will do that! Thank you very much.
I'm almost 99% sure it's the pump. Or else, why would the belt be squeaking so bad? I had a leak in my power steering line at my gear box in my F150 and it was similarly difficult to steer, but with no belt noise.
NOW, the fun of working within the confines of an enclosed area.
Any tips on what to remove and what not to remove for this repair?
Old Oct 8, 2013 | 05:03 PM
blageurt's Avatar
blageurt
Belt noise might be a SEIZED pump...what was the fluid level / condition like...was it foamy ?
Old Oct 8, 2013 | 08:32 PM
spindlebox's Avatar
spindlebox
So I got the belt off the pump and went to start taking bolts off. Noticed there was a bit of play on the pulley, darn thing pulled right out!
After I got it out, I noticed there is a little silver ring at the end of the shaft, that had split.
So long story short, I put the OEM part I got in and I don't even notice that slight "grating" sound when turning the wheel. Whisper quiet.
So thanks so much for your help! It turns out my first hunch was correct.
deezel
2004 - 2008 F150
Apr 3, 2011 07:53 PM
wanta79
Apr 11, 2010 10:20 AM
Old and Busted
Nov 17, 2008 02:20 PM
bc30629
Jul 19, 2004 01:02 PM
