Throttle/Shifting Issue
Old Oct 6, 2013 | 10:02 PM
HunerdProof1371's Avatar
HunerdProof1371
Truck is having two issues that are quite disconcerting. First is it is very slow to shift and hard shifting in the mornings if I don't let it warm up, the rest of the day it is fine.
Second, at any random time it so chooses, my truck has little to almost no throttle response. There's some, but definitely not what I need pulling onto the highway.
I took it to Autozone and had them run a scan gauge on it, can't remember the code (P2xxx ?) Low Injection Control System Pressure.
Is this my FICM?
Old Oct 7, 2013 | 10:47 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Slow to shift when cold is common especially if it's running a little ragged from injector stiction or other issues. The trans will likely straighten up when the running issues are fixed.
Hard starting in the morning could be a FICM issue. There are instructions on how to test it in the tech folder, quick and easy. If it fails the test it can usually be repaired much cheaper than replaced. Running ok after it warms up is consistent with a FICM problem.
Random loss of power can have several causes and can be a pain in the but to chase down. It's hard to say with the info provided.
We love codes around here unfortunate you don't remember which one you pulled but low ICP is related to the high pressure oil system. On the '03 the high pressure pump might be the first suspect. But could be the injector pressure regulator (IPR) or the ICP (injector control pressure sensor) it's self.
Except for testing the FICM (if your comfortable with a multimeter) you really need an OBDII monitor of some sort. The ScanGaugeII is a popular choice along with smartphone apps. Some higher end scanners at the parts store do "live Data" also. Computer based software is more powerful but more expensive also. AutEngenuity is a popular choice.
As always, if the oil and fuel filters aren't up to date it's always worth a shot to do those. Be sure you are running the shorter OEM oil filter cap and Motorcraft/Racor filter.
Cool screen name btw! I was in a local bar band we called 80Proof for many years.
Old Oct 7, 2013 | 05:22 PM
HunerdProof1371
Thanks for the info Rusty, I'll take it back by autozone (less than 1mi from my house, that's why I don't have a scan tool) and get the specific code.
Old Oct 7, 2013 | 06:05 PM
BLADE35's Avatar
BLADE35
P2285??????
Old Oct 7, 2013 | 07:57 PM
HunerdProof1371
Blade, I'm almost positive that was it
Rkarpik
Aug 11, 2019 11:39 AM
Pikachu
Dec 8, 2015 08:03 AM
sportsdad
13
Jun 8, 2014 05:06 AM
chev69ss
Jan 18, 2012 10:19 PM
castroke#1
Nov 20, 2010 07:29 PM
