Question on soldering practices/methods
Old Oct 6, 2013 | 10:47 AM
DBGrif91's Avatar
DBGrif91
I was curious to know:
When using standard solder to repair wiring, and then using heat shrink to cover the joint, is it advisable to dab a little dielectric grease on the joint before using the heat shrink? Would there be any advantage to it, or does the heat shrink do a good enough job of sealing if it's done right?
I know there's certain types of heat shrink that have a glue or sorts in them, but I'm asking for general reasons. I need to repair some tail light wiring and with it being at the back of the truck, where all the water, salt, and road grime are thrown as I'm driving, I thought dielectric grease could work IF it's not harmful in the sense of the heat from a mini torch ruining the grease.
Old Oct 6, 2013 | 10:53 AM
SideWinder4.9l's Avatar
SideWinder4.9l
It'll want to run, etc but no issues.
Old Oct 6, 2013 | 10:56 AM
MT4x4guy's Avatar
MT4x4guy
Dielectric grease will never hurt an electrical joint.
Old Oct 6, 2013 | 10:57 AM
DBGrif91's Avatar
DBGrif91
Thank you. I didn't think that the grease itself would be a problem. What concerned me was the heat from the mini torch causing it to break down somehow and then it's actually more harmful than helpful.
Old Oct 6, 2013 | 11:48 AM
Bob Gervais's Avatar
Bob Gervais
I usually use liquid electrical tape, then the glue coated heat shrink tubes.
Old Oct 6, 2013 | 12:12 PM
Volvo92906's Avatar
Volvo92906
Liquid electrical tape is EXTREMELY flammable.. Ask me how I know.
I think dialectric grease is useless. But thats just me.
If its done right, heat shrink tubing alone will seal a connection. I have done a LOT of electrical repairs working on tractor trailers. I have never had to redo connections I soldered and heat shrinked.. But I did have to redo connections done with silicon, butt connectors, and electrical tape. (Quick repairs, but not designed for longevity)
Old Oct 6, 2013 | 12:17 PM
MT4x4guy's Avatar
MT4x4guy
There are actually very few things that silicon is good for, ask me how I know!
Old Oct 6, 2013 | 02:21 PM
DBGrif91's Avatar
DBGrif91
How DO you know?
How DO you know?
I think it's funny that people make statements like that and nobody ever asks them how they know.
Old Oct 6, 2013 | 02:28 PM
Volvo92906's Avatar
Volvo92906
Hahaha, Nice DBGrif.
Well ill tell you anyhow.. I was working on a semi trailer harness that had rubbed through and decided after doing the repair on multiple wires, I would put liquid electrical tape on it. I realized after applying I had forgotten to heat shrink one of the tubes over my connection. I grabbed my mini burnzomatic torch and proceeded to shrink the tube.. The whole repair went up in flames under the trailer. The driver was asleep in the cab. That was a pucker moment. Fortunately no damage occurred.
Old Oct 7, 2013 | 02:32 AM
Ninra's Avatar
Ninra
Solder Flux
I've soldered many joints and flux makes a big difference. Depending on the gauge of the wire, I use slightly different techniques. For a small grade wire I twist the ends together, lay the connection flat, flux, solder, (I use a soldering iron), I use one wrap of electric tape and then heat shrink the whole connection. Granted, I am an electronic technician so I tend to be a little pedantic about connections, those little plastic splicers drive me nuts!
Old Oct 7, 2013 | 02:39 AM
dirtsdirtydiesel's Avatar
dirtsdirtydiesel
it always depends where it is, I don't solder in any application where there isn't much movement or vibration, I use a red head, and double wrap the tape. I am an apprentice C6 electrician and I've never used the grease even on 48v applications. I use soldering on speakers ECU systems and in connectors but not two separate strands of wire. If you crimp wires together correctly I think theyre more effective and do not add or remove resistance.
Old Oct 7, 2013 | 05:22 AM
dixie460's Avatar
dixie460
Me too. Only thing they're good for is emergency repairs to get you going again. Actually not even, that's what wire nuts are for. I hate when I buy a used truck and find those blue t-tap connectors everywhere... THOSE should have never been invented!
As for the dielectric grease, I only use it to seal water out of things like trailer power connectors and spark plug leads. For a solder connection in a harness or whatever, the proper size heatshrink tube will do the job.
Old Oct 7, 2013 | 07:54 AM
DBGrif91's Avatar
DBGrif91
The diesel mechanics at work often use butt connectors that have a glue of some kind in them and the casing is heat shrink. After they're crimped on, the heat melts the glue and the casing to provide a solid seal. I'd have no problem using those in place of solder almost anytime- problem is that that they're expensive, which is why I opt for solder.
Even if I find myself in a position to use a plain butt connector for sake of time or a quick repair, I'll heat shrink the repair anyway just to prevent corrosion from taking hold on the wire.
Old Oct 7, 2013 | 08:06 AM
bashby's Avatar
bashby
I am a big fan of these also. The regular ones not only let moisture in, but the wire tends to bend back and forth and break right next to the connector.
I see no need for dielectric grease on a solder joint.
Edit: I get the heat shrink butt connecters at Walmart, price isn't too bad.
Old Oct 7, 2013 | 11:22 AM
DBGrif91's Avatar
DBGrif91
I guess I didn't think to look for them at wal mart. We get them at work from midwest wheel, but we also buy in bulk so maybe it evens out.
I keep forgetting to mention that the reason I thought of using grease on the joint to begin with is that, IMO, there's never "too much protection" when it comes to electrical repairs. It's insane how even a small break in sheathing can cause corrosion to spread through the wire and before you know it, you have to replace a long section of it.
On my tail lights I noticed that corrosion has spread much further back than I thought, so for now I just made the necessary repair to get them working properly again. In the next couple of weeks I'm going to have to cut out all the wiring for both tail lights and replace it. I have the PO to thank for that- when he wired in the trailer sockets (one 7 pin in the bed for a 5th wheel and a 4 pin at the rear) he used... you guessed it... SCOTCH LOCKS!!!
I have been finding scotch locks all over this truck since I bought it. I'm not 100% against them- I think in certain applications they work quite nicely- but not when you're cutting into wires under the bed!!!
_-End Rant-_
We're all good now.
