ford truck upgrading help
Old Oct 5, 2013 | 10:50 PM
1985tullyhowell's Avatar
1985tullyhowell
I have a 1985 f150 300i6 np435 custom 4x2
and have some questions on upgrading and mpg /upping power
how would you put a electric fan on these trucks ( minus the clutch fan)?
do under drive pullies work?
upgrade the breather? (mine previous owner chopped out the vacuum motor and heat switch for "better breathing)
weight reduction?
etc..?
Old Oct 6, 2013 | 01:50 AM
oneowner83's Avatar
oneowner83
Change to overdrive and run standard size tires!
Old Oct 6, 2013 | 06:30 AM
Franklin2's Avatar
Franklin2
The undersized pulleys if you can even get them do not go along with the electric fan idea. The electric fan draws a lot of current and usually requires a larger alternator to run it. The overdrive tranny is a good idea.
Old Oct 6, 2013 | 08:36 PM
1985tullyhowell
well the tires I have on it are ... 235/75r15
stock spec. plate says 215/75r15
would taller(not wider ) tires work at keeping rpms down with out to much drag?
it has 3.08 geared rear axle ( which is as high as I want to go)
at {55}mph it stays at 2000rpm ( sound a little high ,or is that perfect) being a basic custom and geared for "highway" use is what I would think 3.08 is for....?
Old Oct 6, 2013 | 09:04 PM
Franklin2's Avatar
Franklin2
Sounds like you have the best of everything already. It takes a certain amount of power to push a brick through the air, so going slower will be one of the few options you have. I think if you went with a overdrive tranny, the six would not have enough power to push that truck very fast with a 3.08 gear. Or you would be constantly shifting it in and out of overdrive. It might be ok if it's flat where you live.
Looks like you have about the right tire on it also.
One thing we forgot to ask; Is this truck's engine all original with the original emissions controls all hooked up and working? This truck has a computer to run it, and if it's been messed with, that's where all your fuel mileage has gone.
Old Oct 6, 2013 | 09:17 PM
1985tullyhowell
Well the emissions ,computer ,and feed back carb are all gone except "EGR" valve ( need to figure out how to get that working again).
The emissions and feedback car previous owner removed , ran like ***** , etc. converted to Dura spark ii.. Now here I am,
wanting better mpgs and power through little mods etc..
any more questions? just wondering ... no problem
Old Oct 6, 2013 | 09:45 PM
1985tullyhowell
taller tire better rpms or should I go back to stock 215s?
79FordBlake
Jun 25, 2011 11:49 PM
Elderstarr
17
Sep 10, 2009 04:34 PM
maddogken
Aug 30, 2009 06:05 PM
cvanover
Mar 30, 2005 03:17 PM
'72 12'flatbed
Feb 15, 2005 06:40 PM
