Sponsored by: Real Truck
2010 250 Coolant test?
Old Oct 8, 2013 | 08:35 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by Fordfenders
I know the TSB requires Motorcraftâ Premium Gold Engine
Coolant with Bittering Agent.....does anyone know what color this is? The MSD sheet says clear but I am thinking it is gold colored? Anyone know?
The coolant is gold. There are two versions of the gold coolant. VC7 and VC7B. B stands for buttering agent. Its the same coolant but sold in states that require the bittering agent to deter wildlife from drinking it.
Old Oct 8, 2013 | 08:41 PM
Fordfenders's Avatar
Fordfenders
Thanks guys, I did pull a sample the other day and it did look gold to me, so that tells me it probably has the Motorcraft Premium Gold Engine
Coolant. My strips came in today to test but the truck is too warm right now but I will be testing it soon. I will keep you posted!
Old Oct 9, 2013 | 01:15 PM
Fordfenders
Hi I read somewhere that the 6.4 (and other diesels for that matter) will increase their idle when it is cold, I guess this prevents wet stacking? For prolonged idles. Anyway, I read that the emergency brake must be engaged, know anything about that? Mine seems to idle a bit faster on cold mornings and I don't use the e-brake....I have a 2010 by the way...thoughts?
Old Oct 9, 2013 | 01:44 PM
senix's Avatar
senix
e-brake is not needed for the cold weather high idle strategy. I will bump itself up to around 1K-1200 rpms if in park.
Old Oct 9, 2013 | 01:45 PM
Pitcrw6's Avatar
Pitcrw6
Hi I read somewhere that the 6.4 (and other diesels for that matter) will increase their idle when it is cold, I guess this prevents wet stacking? For Iprolonged idles. Anyway, I read that the emergency brake must be engaged, know anything about that? Mine seems to idle a bit faster on cold mornings and I don't use the e-brake....I have a 2010 by the way...thoughts?
sounds normal. It should go back down when you tap the brake. Thats a normal function on a 7.3.
Old Oct 9, 2013 | 01:48 PM
Fordfenders
Thanks guys, I just checked my nitrates and all is good! My nitrates exceed the 800 so that is a relief!
Thanks again.
Old Oct 9, 2013 | 01:49 PM
senix's Avatar
senix
Great so just check again at the next oil change interval or fuel filter change time whichever is farthest away.
Then check with those fuel filter changes each time.
Old Oct 9, 2013 | 01:54 PM
Pitcrw6's Avatar
Pitcrw6
I was trying to respond to fast because I something to do but the e brake dont need to be set. High idle comes on at a certain temp and goes off when you tap the brake.
strokeithard
16
Mar 2, 2017 02:41 PM
camdaddy
Sep 22, 2013 07:52 PM
Canadian F250
6.7L Power Stroke Diesel
Nov 3, 2012 02:15 PM
sterling
Feb 8, 2005 08:47 AM
sdmotor
Oct 17, 2002 09:58 AM
