Good evening,
Lights are dimming whenever I let off the gas and come back up whenever I get back on the throttle. Wondering if it could be the battery or the alternator or something more sinister like the wiring...
Thanks in advance.
Good afternoon,
Sounds like take the time and replace all three? Or just one at a time and maybe it will go away. Or is that a problem that will reappear if not all three i.e. (votage regualtor, battery or alternator) are fixed?
Thanks
If that doesn't cure it there is also a very good wiring diagram on this site that will help you out also.on my crew cab everything was new and still did that,so I tested the voltage at the lights and had about 8.5 volts ford in there infinite wisdom used very small wire in there head light wiring its like 14 or 16 gauge wire and with that diagram I put larger wire in and some relays and my light never dimmed again
Gentleman,
Replaced the voltage regulator, still the same problem had some suggestions. What would be the best approach to tackle next. I have the battery disconnected I am working under the dash right now so now is prime time to pull the battery and change it I guess? Just looking for words of wisdom.
Did you get the alternator bench tested? You can simply drive it there and pull it in the parking lot and walk in with it, if you only have one vehicle to drive, I've done it.
