Factory Nav problem
Old Oct 3, 2013 | 05:29 PM
cford716's Avatar
cford716
Factory Nav problem
Has anyone had positioning problems with their factory nav? Specifically it will randomly shift left or right several hundred yards. At that point it starts grabbing the nearest road and giving me directions to get back on the route I am already on. This can go on for 5 to 10 minutes or more before it "finds" itself. The more roads the worse it is.
What I have noticed:
- shifts left or right several hundred yards
- seems to lag by maybe 100 yards and then make a turn and it is then offset from your current position.
- no help from updating to the current software, actually seems to be getting worse.
It is making it basically unusable unless you are on a straight highway and stay on it. It would be useless in a city.
No, haven't had it to the dealer yet. Hopefully get in in next week. Just wondered if anyone else has run into this.
2013 F-150 FX4 with factory MyFord Touch with Nav
Old Oct 4, 2013 | 04:02 PM
bdmcdonald's Avatar
bdmcdonald
Nope, works great in town and out of town.
Old Oct 4, 2013 | 06:04 PM
PrinceValium's Avatar
PrinceValium
There was an update released that helps address this issue...go to MyFordTouch,com and download the update.
Get the Latest Software Updates | MyFord Touch | Ford.com
Old Oct 4, 2013 | 06:27 PM
cford716's Avatar
cford716
Is it an update since the new software that came out last month? I recently did an update about a month ago. If that is the last one, it didn't help.
Old Oct 4, 2013 | 06:34 PM
cford716's Avatar
cford716
I just checked and Sync is up to date with ver 3.6.2
Old Oct 4, 2013 | 09:56 PM
PrinceValium
I know that you can also do a hard reset of your touch system that might also take care of it. Look it up on the site. (you still keep your stations etc.)
Old Oct 13, 2013 | 03:22 PM
cford716's Avatar
cford716
Well I did find a "fix" for this. Found it on another forum........disconnect your negative battery terminal for about 2 hours. Has been working fine for over a week.
Old Oct 14, 2013 | 10:19 AM
SabreFX4's Avatar
SabreFX4
I don't have factory Nav, but even the Garmin I use will do this occasionally. I sometimes wonder if it has more to do with how many satellites it's able to receive right then....more satellites received, more accuracy?
thunderbolt427
2004 - 2008 F150
Oct 19, 2023 09:56 AM
dave91gt
Sep 3, 2018 10:30 AM
Trailblazen
2009 - 2014 F150
29
Feb 27, 2016 07:04 AM
