Sponsored by: Real Truck
Long Bed Conversion
Old Oct 2, 2013 | 05:33 PM
Donovan2769's Avatar
Donovan2769
Long Bed Conversion
I am trying to find any information on whether or not a 2013 F-350 Super Duty Long bed will mount to a 2001 F-350 SD Chassi? any help is appreciated.
Donovan2769
Old Oct 2, 2013 | 05:35 PM
Tom's Avatar
Tom
Hi Donovan, welcome to FTE!
Unfortunately a pickup bed will not mount to a truck sold as a cab/chassis, as the rear frame is different. I'm sure there is a way to make it work, but it would likely require some fabrication.
Old Oct 2, 2013 | 06:22 PM
xmontex4's Avatar
xmontex4
Tom is right, however there is a thread i believe on here where someone took an F450 or 550 and turned it from a flatbed into a dually pick up I'll see if i can dig it up for you, he even put air ride seats in it.
Old Oct 2, 2013 | 08:23 PM
GregsSD's Avatar
GregsSD
If you are not talking about a cab/chassis, but a 2001 F-350 with a pickup bed, then the beds will swap fine.
But the 2013 bed has some different body lines around the fenderwells, so it won't look exactly correct, but very close!
Old Oct 2, 2013 | 09:29 PM
05F250DSL's Avatar
05F250DSL
As long as they both are Long bed trucks it shouldn't be that hard. A co worker put the newer 08'+ box on his 2001. I don't recall him having any major problems. Other than as mentioned the body lines are a bit different.
Old Oct 2, 2013 | 09:38 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
C&C trucks use 34" straight rails, pickups use a 37" width.
Old Oct 13, 2013 | 03:14 PM
Donovan2769
Bed swap
I apologize not being clear. I own a 2001 F-350 SD in which the bed is rusting bad. I have found a bed that came off a 2013 F-350 SD. My question is will it fit on my 2001? Thank You
Old Oct 13, 2013 | 03:16 PM
Donovan2769
Thank you for answering my question. I thought that it would fit but not sure so that's why I asked.
Old Oct 13, 2013 | 03:19 PM
rollerstud98's Avatar
rollerstud98
Will have to swap some wiring over. Nothing serious.
Old Oct 14, 2013 | 08:37 AM
xmontex4's Avatar
xmontex4
The filler neck will also not line up perfect but its flexable so it can be manuvered into position.
SilentLlama
18
May 8, 2017 09:42 PM
Ryan313
Feb 1, 2015 12:31 PM
64f100292
May 23, 2014 10:47 AM
jumbaco
Jun 22, 2013 05:41 PM
alex1985blue
Jul 31, 2012 12:57 AM
