Can't steer!!!
Old Oct 1, 2013 | 09:53 PM
mcd432's Avatar
mcd432
Can't steer!!!
I get like 0 power steering when I'm trying to park or not moving. Is my best bet to start with the lower steering shaft, or the pump??
Old Oct 1, 2013 | 10:33 PM
jr105's Avatar
jr105
That doesn't sound like the lower shaft.
Old Oct 2, 2013 | 11:15 AM
wolfy's Avatar
wolfy
Simple things first. How is your power steering fluid? Is there any there? I agree that doesn't sound like a shaft.
Old Oct 2, 2013 | 10:33 PM
mcd432's Avatar
mcd432
Oh it's full. I started with a PS flush, and cleaning and greasing the shaft ujoint
Old Oct 3, 2013 | 09:24 AM
1saxman's Avatar
1saxman
Check PS pump pulley. Take tension off drive belt and turn pulley to check on slow speed pump action. It should turn easily but there should be some feel or sound of pump action. Is drive belt in good condition? Pump might be worn out and not working well at low speed. Put trans in Park and run engine up to 2000 RPM to see if pump action improves - I think that will tell the tale.
waine5
Jan 16, 2018 01:44 PM
yasky69
Modular V10 (6.8l)
Aug 22, 2010 11:35 AM
monkei
Feb 27, 2004 04:21 AM
troysbowman
1978 - 1996 Big Bronco
Dec 10, 2003 04:21 PM
