UPDATE: Crank/No Start...
Old Oct 3, 2013 | 04:12 PM
427 fordman's Avatar
427 fordman
Not sure on the abs light, check the single wire connection on the alternator for the battery light.
If your injectors are firing, you should see smoke while cranking, especially a longer crank. If they are not, you won't. That leads towards an idm/ipr/wiring problem.
And you are right, it won't start with the ipr unplugged. It will with the icp unplugged.
Old Oct 3, 2013 | 04:31 PM
wezol5484's Avatar
wezol5484
Thanks fordman. That actually gives me some hope that I'm not chasing problems and may of actually been on the right track. Although, would I still smell raw diesel in the exhaust if the injectors weren't firing?
I'll check the alternator wiring, maybe it's shorted out on something. I have the batteries unplugged for the time being so I don't drain them.
Old Oct 3, 2013 | 04:48 PM
427 fordman
I'm pretty sure you'd smell the raw diesel. The injectors fire on high pressure oil so I THINK if they are getting fuel you'll smell it.
I'm not positive on that, so someone correct me if I'm wrong.
Old Oct 3, 2013 | 05:16 PM
wezol5484's Avatar
wezol5484
So if I understand what you're saying correctly, the injectors are getting fuel which is why I smell the diesel, but aren't actually firing which would be due to the IPR or something in line with HPO getting to the injectors. I know the basic mechanics of how the powerstrokes are run, so what you say makes plenty if sense.
Old Oct 3, 2013 | 05:41 PM
427 fordman
You are. That's what I'm saying.
Old Oct 3, 2013 | 05:59 PM
oldbird1965's Avatar
oldbird1965
I don't think the IPR would have any thing to do with the ABS & battery light. I don't know what would.
Old Oct 6, 2013 | 03:15 PM
wezol5484's Avatar
wezol5484
Thanks guys for the help. Got it started, abs and battery light have gone away. But now has a miss. I started a new thread in the topic.
Alan Valek
Sep 25, 2017 07:59 PM
Eliteac
6.7L Power Stroke Diesel
82
Apr 21, 2014 06:40 PM
cowmilker08
Aug 19, 2011 04:54 PM
Cowboy350
Apr 20, 2005 10:45 PM
