Microtuner 1705 w/ 3 settings?
Old Jun 18, 2003 | 08:01 PM
TimC63's Avatar
TimC63
Does anyone have any information about a Superchips Microtuner 1705 that offers three power settings?
Does anyone know if there will ever be a Predator application for 94-97 Powerstrokes?
I do not want to start the age old brand vs. brand debate, but I am interested in a product to safely get more power when towing. Other than a K&N, down pipe and missing cat (gauges too), I am otherwise stock and tow a 7,500 lbs. travel trailer.
Thanks for any input, I find the site very helpful!
Old Jun 20, 2003 | 10:17 AM
bricot's Avatar
bricot
Unless they are referring to stock, 60HP, and 80HP as being three settings, I haven't heard of a SCMT with 3 settings in addition to the stock program.
Apparently pre-99's aren't a large enough market for them to be in any hurry to develop the Predator for. I have the SCMT and may look at the Predator if they decide to release one for the pre-99's.
I'm happy with the SCMT, if you have gauges and a downpipe you have what you need to run it. I run in the 60hp mode and picked up 3-4 miles per gallon !
Old Jun 20, 2003 | 10:21 AM
FTE Ken's Avatar
FTE Ken
The SCMT is only available with 2 tunes. Hypertech has a 3 program tuner but its highest setting is 50hp so the two lower settings are useless. Diablo will eventually get a pre-1999 tuner out after the 6.0L PSD and gas V8 tuners are out.
Old Jun 21, 2003 | 11:20 PM
edstoner's Avatar
edstoner
I went on a web site with the same name as "microtuner" and they have the 1705 listed with three power settings, 70/90/100 HP. Hope this helps.
Old Jun 21, 2003 | 11:44 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
What website? That is not a 1705 SCMT.
Old Jun 21, 2003 | 11:50 PM
FTE Ken's Avatar
FTE Ken
I confirmed with Superchips that the shipment of tuners we'll be getting this Monday will have 3 tunes instead of 3. Its just been updated.
Old Jun 22, 2003 | 12:03 AM
cookie88's Avatar
cookie88
FTE Emeritus
Are 70/90/100 the actual settings? And if so, what's the point? 70/100 I can see, but why would you need two settings 10hp apart, it's not like you would be able to feel a 10hp increase. Also, why would they change the settings that they've built the company on? Seems like there would be alot less work involved if they just went 60/80/100.
Old Jun 22, 2003 | 01:17 AM
FTE Ken's Avatar
FTE Ken
They figured out how to program higher horse power with lower EGTs.
Basically, they can give you 70HP with the same temps as the 60HP, 90HP with the same temps as 80HP. They have a tradition of not going too extreme so that's probably why they didn't go over 100HP.
Old Jun 22, 2003 | 07:32 AM
ubon's Avatar
ubon
Brian, How much trouble is it to install the sonnax shift valve and the tricummulator springs, I've got a trans-command on it now, and can I run both?? Thanks for any info.
John in Tampa
Old Jun 22, 2003 | 11:41 AM
FTE Ken's Avatar
FTE Ken
John,
Please post new topics as a new thread.
Thanks,
Old Jun 23, 2003 | 09:29 AM
bricot's Avatar
bricot
Ken are the SCMT's reprogrammable/flashable? Didn't know if they could update the older SCMT's with the newer program.
I hate waiting for Diablo to 'catch up' and release the predator for pre 99's ...
John if you start a new thread I'll respond.
