Noise battle!
I've been reading about intakes on your forum and would like some advise on the most quiet one but still deliveries the air the s366 wants, like the 6637 does. I've read about the AFE, AIS, S&B, stock SD box and the stock 6.0 box. What do you guys think would be the most quiet? At this point I don't care about the cost, I would rather keep my 7.3 then spend a lot of money on a 6.7! LOL
Also, I'm all ears on the best sound proofing material I can get. Thanks a lot!!
If I were you I would contact clay at riffraff and get his opinion on your intake situation.
Also dynomat or something similar (there's a few threads about this) on the inside of the truck should now a big difference.
If you want to go the extra mile thrres also something that you can use as an insulator on the underside of the truck. I believe it is called lizard skin? I seen it on powerblocks TRUCKS.
I'm sure if you got a few cans of truck bed liner and sprayed the underside of the truck it won't make much of a difference but with your situation every little bit will help.
Now mare in your signature shows is a 97 that's a little different then what were used to here but the same principles apply.
Sound Deadening 101: Know your products - PowerStrokeArmy
The cold air box around a 6637 or afe stage 2 help quite a bit with certain frequency noises, but are useless for other noises like turbo whistle.
Don't know everything about the down under trucks, but wrapping you passenger side CAC tube will help with sound some. Later 7.3's in the states came with our driver side CAC tube wrapped in a thin layer of fiberglass insulation and foil.
I feel for your wife. I used to work for a railroad and most older locomotives were extremely loud in the cab under load. Besides hearing damage, it was a major stress factor. At various times the company issued Dave Clark headsets, custom fitted earpiece/plugs, shooting muffs and, of course, the standard generous assortment of ear plugs. The worst for the driver was the close proximity radio speaker which was cranked way up to overcome the engine noise.
What made a world of difference was the newer rubber mounted cabs. The cab actually floated in a cradle/bed of 2-3 inch accordian type isolation rubber. FYI, those cabs that have this feature have a black slotted band across the nose about 1 foot in front of the windshield/windscreen which is the easiest part to see. It was particularily efficient at nulling low frequency sounds or vibrations characteristic of large low rpm engines. Higher frequencies can be blocked by solid firewalls, thick glass and due care to sealing plumbing and electrical.
I wonder if you couldn't temporarily replace the air cleaner/snorkel with a factory OEM unit while traveling long distances with your wife. Looking at the picture of your 5th wheel, it probably doesn't take even 100 horsepower at cruise, and doesn't need open filters for cruise conditions. You could always replace the OEM with an open type just for actual racing. One thing I'm not well aware of is how noisy aftermarket turbo design's might be, so perhaps a quiet, well designed OEM intake wouldn't do the trick.
If the exhaust is also too noisy, I have temporarily added a small muffled tip to the end of an open exhaust with some success. Unfortunately what I added was rather restrictive, but worked well at slow speeds unloaded around the city with low exhaust flow requirements. The highway towing could be a problem unless one could temporarily exchange/install an entire quiet muffler the last few feet of straight pipe. It is my understanding that there is very little difference in fuel consumption.
When the little woman is happy, everybody is happy. Good luck.
Wes
First I stripped everything out of the cab. Then I used a sticky rubber/tar type of layer on the first layer for all of the floor (I believe it was called "Stick & Seal" or something... got it in the roofing section of home depot), and also laid a second layer of it down on the lower floor pans. Used aluminum foil tape around all of the edges and seams.
After that, I used a thin type of heater duct insulation (not the toxic looking stuff, but a closed cell type). Used 2 layers of that in the floor in most places, but went up to 3 layers in parts of the floor and trans tunnel. Put 2 layers of it on the roof above the headliner, and 2 layers behind the seat on the back of the cab, again using foil tape at all edges and seams. Used one layer in the doors directly behind the panels.
Used a decible meter before and afterward and dropped 34% sound at 55 MPH. I was very happy with the outcome. Cost me $96 in materials and about 6 hours work.
Here's a pic of the drivers side floor right before I laid the carpet back over:
Barney
Wes
Barney
Ford F550 Super Duty - Diesel Tech - Diesel Power Magazine
I haven't read the whole thing yet but looks to be some good info
and these are the folks the story is about, looks like around 500 will get you a complete kit. Firewall, doors, floor and rear of cab.
QuietRide Solutions
Quite ride ford catalog
http://www.quietride.com/catalogpdfs...10_catalog.pdf
I like the fact that it appears they have done some engineering on the kits rather than a more is better approach, Not that there is anything wrong with that. Quite is quite no matter how you get there.
