factory stereo wiring / plugs
factory stereo, whats the 2nd plug for?
so i went to remove the factory unit to install my new jvc unit, and discovered there are two plugs in the back of the factory unit (and the adapter I got was incorrect).
while the long thin one seems pretty obvious as the connector matches...whats the square one for? The rear controls etc?
do you have to even bother with this or can you just leave it unplugged if you dont care about rear volume controls?
Id read on other threads that disconnecting the rear volume controls can disable the rear speakers? or is that just someone screwing something up?
is there an adapter that would let you connect both of those plugs to the aftermarket stereo harness?
this is epically ridiculous.
the more I search, the more different "adapters" say will fit...and clearly some just flat out wont.
the long thin connector appears to have 14 pins.
the round one with 3 rows of pins I count 20 on.
both go into the same "bundle" in the dash....my truck does not have a rear entertainment system/dvd.
That square one is a 'new world' connector that carries the audio for the DVD player (if equipped, power for the screen (if equipped).
I'm fairly certain that Ford used the same wiring harness regadless of if it had the DVD player or not. You don't care about that plug, you only care about the 'phase 2' rectangular plug. You will lose the headphone out in the 2nd row and the volume control.
Note that the rectangular plug carries the audio for all 6 speakers (the 3rd row is a 2nd set of rears).
thank you sir!
next question (after I finish smacking the guy who told me to buy all this crap that doesnt work upside his head)!
does anyone make a double din mounting bracket that allows you to remove the radio (using insert/tools is fine) without removing the dash panel after installing it?
the kit I bought specifically says "you cannot remove this radio without removing the dash panel after installation"
this seems.....well....completely effing retarded.
If you find one let me know. I haven't 'properly' installed my new head unit yet because of this.
thank you sir!
No. It is such a modified fit there is no premade kit that allows for easy removal. Make sure you pull the bolt in the cavity above the hu. And the rear audio is split at the headphone panel, only four channels are present in the rectangular connector. Yank that and you lose the rears all together. Note that you will have weak rear audio unless you are using a 2ohm capable hu or amp. Or disconnect one of the rear sets.
EDIT:
Here are your connector views for reference.
EDIT:
The following users liked this post:
I'm not sure that's correct. In my '02 I still get audio through all the speakers if the New World connector is left unplugged. As you've said however, you're now splitting the power for the rears between 4 speakers. I'm looking to install this little guy to power the two rears Amazon.com: Sound Storm Laboratories EV2.200 200-Watt 2-Channel Power Amplifier with High/Low Crossover: Car Electronics
comments on this one say it allows for the radio to be removed without the dash panel
at 7 bucks, i gave it a shot...will let ya know.
are the 3rd row speakers just 1way single cones? or 2/3way multi style speakers?
Well I just bought that too. I can see how you can just take the bezel off to expose the radio which is good.
The 3rd row speakers are single cones. I just replaced all 6 of my speakers though with 4 ways.
Amazon.com : Ford Double Din Dash Kit : Ford Explorer Accessories : Electronics
That is Ford's wiring diagram, I would hope that it's right...lol
I didnt say that any speakers went through the RSE connector, only that there were only 4 channels present at the main connector. It is split further back at the headphone/rear control panel. If you yank the panel, like removing the console, you lose the rears. The OE system is still only a 4 channel audio system, no matter how many speakers they crammed in there. The OE head unit is 2ohm capable and powerful enough to handle the split off.
