Injector plug question
Old Sep 30, 2013 | 10:29 AM
dvcroket's Avatar
dvcroket
#4 plug fried & found some oil inside plug. This is my daily driver so I need to get running ASAP. Should I just try new external pigtail first or assume UCVH is also bad and buy pigtails, gasket, & UCVH's for that whole side. Where is the best place to buy these parts?
Old Sep 30, 2013 | 11:04 AM
farmert's Avatar
farmert
With oil in the plug, I would say replace the gasket along with the external plug, if that is the plug that is melted. You can get the Chineese made Doorman gasket from most any parts house, but there are mixed reviews on their longiviity. With the Doorman you get the gasket, both external plug pigtails, and both the UVC harnesses. Clay at Riff Raff has OEM gaskets and plugs.
Old Sep 30, 2013 | 11:17 AM
fordman67's Avatar
fordman67
Which part of it fried?
Check the glow plugs.i would replace it all.ford parts are best.
i have a cheap doorman on one side for almost 2 yrs.some don't like and i would rather have ford.i was in a bind though
Old Sep 30, 2013 | 11:22 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Here are some links for you.
Riffraff Diesel: Ford Valve Cover Gasket 94.5-97
Riffraff Diesel: Ford Under Valve Cover Harness 94.5-97
Riffraff Diesel: Valve Cover Gasket Connector Pigtail 94-97
I strongly suggest staying away from Dorman. After changing out Dorman injector orings twice in a month I changes to OEM from Riffraff and that was over 4 years ago. Dorman specializes in making junk parts in China for cheap prices.
mswpj
2004 - 2008 F150
Feb 1, 2011 09:06 AM
60man
Jun 19, 2007 11:06 AM
PigFarmer
Mar 3, 2003 08:13 AM
PigFarmer
Mar 2, 2003 02:23 PM
