has anyone ever used or seen any zone suspension parts. im looking at the 2.5 front leveling lift which is a spring pack and an adjustable track bar.. im also putting the add a leaf from tough country in the rear for 1" then I wanna add slightly larger tires on the stock rims.
dude that's perfect I love that look I mean that's exactly what im lookin for. That is one sharp lookin truck!! couple questions for you.. why did you take the smallest leaf out... why did you chose a block in the rear instead of a leaf... and where did you get your billit emblems I want to ditch my plastic for billit!! or is that a platinum factory option... again badd azz
I removed the smallest leaf because I didn't want to end up nose high. Depending on how bad your springs are sagging, you could end up with 4" of lift with this kit.
Here is a pic of just the front done with the factory block.
The only reason I went with a block over an aal was cost.
